Author: Subject: Head lamp flash ?
907
posted on 19/11/14 at 07:53 AM Reply With Quote
Head lamp flash ?
For the IVA do the head lights have to flash using the dip/main beam stalk ?
Paul G
MsD
posted on 19/11/14 at 08:26 AM Reply With Quote
Nope, mine never worked and it passed it in July.
Mark.
adithorp
posted on 19/11/14 at 08:28 AM Reply With Quote
Don't think h/light flash is a requirement. Via a "column stalk" def' isn't. I wouldn't want to be without having h/light flash though.
http://jpsc.org.uk/forum/
907
posted on 19/11/14 at 08:37 AM Reply With Quote
Great, fantastic.
In that case…… Yeeeeeeeee Ha ! Wiring finished.
Thanks,
Paul G
Barkalarr
Contributor
Posts 942
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 19/11/14 at 10:33 AM Reply With Quote
If you're using the sierra wiring diagram it's really easy (I've done it twice) - I'm not far from you so give me a shout if you need a hand.
907
posted on 19/11/14 at 10:57 AM Reply With Quote
Thanks for the offer but nothing Sierra as far as electrical's, otherwise it might have been easier.
My biggest problems were Nova column to Mini wipers, lights through Nova column & VW switches,
and apparently reversing light is now compulsory so had to get a switch that fits the Lotus gearbox.
Turns out that a Passat switch with a 7mm thick washer does the job.
Paul G
p.s.
Your still welcome to call in if you fancy a cuppa anytime.
Barkalarr
Contributor
Posts 942
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 19/11/14 at 11:03 AM Reply With Quote
Drop me a u2u with your postcode and phone number and I'll see how far you are. Always enjoy a run out.
907
posted on 19/11/14 at 11:30 AM Reply With Quote
U2U'd
