Daf
posted on 12/7/15 at 10:20 PM |
Whats an acceptable way to cover this for IVA?
I’m just going through my final jobs list on the car and the front brake hose end is not IVA compliant, I know it needs to be a permanent solution so
I’m guessing a bit of silicone hose and some cable ties is not acceptable. Any suggestions on an appropriate way to protect it?
Daf
kingster996
posted on 12/7/15 at 10:23 PM |
Assuming you mean brake line fittings, then mine were not covered and passed. The test is for a sphere to contact from the front and my tester said
they can't waggle it around in there! I had powerlites too.
He did say something about the Sierra uprights and the mushrooms needing to be held in by something more than the pinch bolt though. Westfield Sierra
sdv has a plate through the pinch bolt, so was fine.
oh, and make sure your brake lines don't touch the wishbones while turning lock to lock. I "pigtailed" mine.
[Edited on 12/7/15 by kingster996]
I used to be indecisive, but now I'm not so sure
Daf
posted on 12/7/15 at 10:38 PM |
Very interesting - something else I can cross off my list then!
I've drilled and put an extra stud through the mushroom, I've tried to read up on everyone else' failures on here!
What do you mean by pigtailed? I've made mine into a nice S shape so that they don't hit anything.
kingster996
posted on 12/7/15 at 10:44 PM |
By pigtail I mean twisted to form a single spiral, so the hose can spring in and out, but not so much that it kinks.
corrado vr6
posted on 13/7/15 at 05:34 PM |
Mine weren't tested at IVA either nor were they covered
http://r1indy7.wordpress.com/
Daf
posted on 13/7/15 at 06:10 PM |
Thanks guys, they're not covered and the job is ticked off my list!
I will be complaining if I fail on it though
kingster996
posted on 13/7/15 at 06:53 PM |
I take no responsibility for you ending up with a tester in full on Pedant Mode though
prawnabie
posted on 13/7/15 at 07:03 PM |
Are those hoses made with compression fittings?
Daf
posted on 13/7/15 at 07:38 PM |
They are yes, I've got the paperwork to go with them though to show that they have the insert into the hose.
The Black Flash
posted on 20/7/15 at 08:04 PM |
As above, I don't think he'll get the sphere in there. You can buy large polystyrene spheres in virtually identical sizes for a quid or
two if you want to check yourself, or just make a cardboard cut out of the radius, but I wouldn't worry about it.
allaboutfords2012
posted on 5/8/15 at 09:35 PM |
Hi there ive used a lot of these fittings and pipes but never got any paperwork. Where did you get them from?
Daf
posted on 6/8/15 at 10:08 AM |
I got them from demon tweeks - I have the part number on the recept and a matching part number in their catalogue with diagram and description.
I'm hoping this will be okay for mr IVA man - I'll let you know!
