christim
posted on 18/7/15 at 10:08 PM |
Non donor engine, age related plate?
So I was planning on using all the parts from my sierra donor, including the 1.8 cvh. Always with the intention of upgrading when finances allow.
Thing is, I just went and bought a 2.0 zetec on ebay....too good a deal to miss (£80 with all the extra bits!)
Now, can i still get an age related plate using the donor parts but with the zetec in? (I remember reading somewhere a while ago about a points system
for dertermining the plate type, but is that just for new plates?)
....also, will a new loom\ecu be needed for the zetec? Only have the one that comes in the sierra at the moment
Cheers!
[Edited on 18/7/15 by christim]
snapper
posted on 19/7/15 at 05:40 AM |
The points system applies to age related but engine gives a higher point score than other parts
I think if you can use donor gearbox hubs axles brakes diff steering you should be ok
But do check so you are fully aware
I eat to survive
I drink to forget
ReMan
posted on 19/7/15 at 08:32 AM |
Yes should be fine it's how th BEC, still get age related
www.plusnine.co.uk
chillis
posted on 19/7/15 at 10:47 AM |
Is there a reason you want age related? Unless you want to put a private plate on there's no real value in age related over Q on a kit car.
Remember, with the 2.0 Zetec you've just bought if its a post August 1995 engine then you'll need to run a catalyst and engine management
to go with it, whereas getting an IVA with the CVH will not require a cat.
I got caught out many yeas ago on the point thing as its 1 point for axle, 1 for suspension but you must use the donor vehicle suspension for that to
qualify. I though I had 8 points but lost two on the suspension and had already sold the donor engine
Never under estimate the ingenuity of an idiot!
posted on 19/7/15 at 10:57 AM |
I changed the 1.6 pinro engine in my sierra for the zetec at the start, on paper anyway....
loggyboy
posted on 19/7/15 at 12:18 PM |
Points system is for radically altered vehicles not kits. All you need is 2 major components.
Out of
* suspension
* axles
* transmission
* steering assembly
* engine
So providing you have the gearbox, diff and shafts and hubs, and steering rack that ticks 3 of the 2 required.
Mistral Motorsport
Dick Axtell
posted on 19/7/15 at 01:34 PM |
Yep - Change the engine number on the donor V5 document. Simplest way round this matter.
christim
posted on 19/7/15 at 03:48 PM |
Aah like it...Good to know i can use a different engine and still get an age related plate, but cant hurt to tell dvla ive 'switched' the
engine into the sierra before breaking it
gremlin1234
posted on 19/7/15 at 04:03 PM |
don't tell them you're breaking it... just sorn 'til you re-register.
