liam.mccaffrey
posted on 3/8/15 at 08:58 AM |
Age Related Plate-Chassis
I'm building a Midlana-ish middy using the wheels hubs, uprights, brakes and rack from a mk1 mx5. The engine and trans is from my old 02 MG zr
160.
I would like to avoid having Q plate if possible (I have a reason). So my understanding is that with an amateur built chassis I might get an age
related with the engine and trans from the MG. Is that right?
The terminology on the DVLA website states that the chassis must be from a specialist manufacturer, I know folks have had age related plates with home
built chassis. Is my chassis likely to be the problem here???
[Edited on 3/8/15 by liam.mccaffrey]
Build Blog
Build Photo Album
micksalt
posted on 3/8/15 at 09:16 AM |
A trick I've seen is to get the MX-5 V5 updated with a new engine (in this case, the MG engine), then the Mazda/MG mutant is the single donor
vehicle for the purposes of the age-related plate. Engine and gearbox are major parts, so I suspect they score very highly in the DVLA age
determination algorithms.
adithorp
posted on 3/8/15 at 09:44 AM |
As DVLA no longer inspect the cars prior to reguistration (relying on IVA to check the engine/chassis numbers) how would they know what the rest of
the bits came from... other than the form you fill in?
http://jpsc.org.uk/forum/
