locost7-online.com
posted on 10/1/16 at 03:34 PM |
Brake pipe clips
I have a load of the clip in type brake pipe clips are they ok for IVA, they clip into a 6 mm hole in chassis then the pipe clips Ito the m
Locost Xflow 150bhp injected! Sold :-(
Facebook blog https://www.facebook.com/Johns-Tiger-Avon-Build-814223212056368/
PLEASE NOTE THIS MEMBER IS NOT A TRADER.
ian locostzx9rc2
posted on 10/1/16 at 03:38 PM |
I wouldn't want to drill lots of 6mm holes in a chassis personally 2/3mm holes ok .
adithorp
posted on 10/1/16 at 04:24 PM |
Yes fine for IVA as its what tin tops have. As said though it's a lot of relatively large holes in the chassis, so I fitted/riveted ally strip
down the tunnel for the long runs and tags in other areas, then drilled that for the clips. The rivet holes are much smaller than those required for
the clips.
[Edited on 10/1/16 by adithorp]
http://jpsc.org.uk/forum/
