Author: Subject: Starter motor/solenoid contacts covers
tims31
posted on 17/5/17 at 04:44 PM Reply With Quote
Just thinking to IVA and the need to cover the contacts for the fuel pump etc with rubber boots, is it also a requirement to cover the Starter motor/solenoid contacts too?
Ta
Build: http://www.martinsfurybuild.co.uk/
posted on 17/5/17 at 05:19 PM Reply With Quote
I did, simply because the xflow solenoid is a separate unit that's screwed to the chassis. Because of this, the live 12v terminal is VERY close to the chassis, so it seemed sensible to cover it properly. Not covering it would be like leaving the cover off the live battery terminal.
gremlin1234
posted on 17/5/17 at 06:14 PM Reply With Quote
indeed, even if it wasn't an iva requirement, what happens if you drop a nut, screwdriver or spanner in that area?
old style ht leads (the coil/distributor end) covers should work well
[Edited on 17/5/17 by gremlin1234]
tims31
posted on 17/5/17 at 07:14 PM Reply With Quote
Thanks guys. I'll have a look on eBay and see what is available.
Chris_Xtreme
posted on 18/5/17 at 07:26 PM Reply With Quote
done that ! 1) it hurt as I stupidly went in with a too short screwdriver to knock the spanner away and 2) it welds itself up in a mass of sparks and heat!
covered them up after that!
