SteveWallace
posted on 20/5/17 at 09:29 AM |
Repair of steering gaiter for MOT
I was giving the Viento a once over prior to taking it for MOT and I've found a hole in one of the steering rack gaiters. This isn't the
usual split in the concertina bit of the gaiter due to perished rubber, but an oval hole (about 5mm) in the part of it that doesn't expand and
contract. Looks like its been caused by a stone or something taking a small chunk of the rubber out.
Holes in gaiters are MOT failures, but given that its in the bit that doesn't flex, I was wondering if I could simply stick a bicycle inner tube
repair patch over it. This would be a lot easier that splitting the ball joint etc, replacing it, and making sure that I don't mess the tracking
up in the process.
If there are any MOT testers on here, would this pass?
"I know every nut and bolt and cog in that car, I built it myself" - The Prisoner, 1967
ian locostzx9rc2
posted on 20/5/17 at 10:32 AM |
If it's clean and not leaking then there should be no reason to fail it
CosKev3
posted on 20/5/17 at 11:36 AM |
I would put some sealer in it,something like Tiger seal
myke pocock
posted on 20/5/17 at 11:56 AM |
Seems a bit penny pinching to me. Why not just replace it and the jobs sorted?
loggyboy
posted on 20/5/17 at 11:57 AM |
Unlike a cv boot there isnt a caveat for if its leaking.
Simple reason for rejection is :
d. an insecure, split or missing steering rack gaiter
Mistral Motorsport
SteveWallace
posted on 20/5/17 at 12:08 PM |
Its not penny pinching - I actually have one to hand already. If anything its laziness and the fact that its raining all the time and I cannot get to
that corner of the car very easily whilst its in the garage.
I might do the inner tube repair but take the new one with me and just ask for half an hour to replace it at the end of the test if it turns into a
failure
[Edited on 20/5/17 by SteveWallace]
posted on 20/5/17 at 01:57 PM |
Apply a bit of silicon sealant ,
chris
posted on 21/5/17 at 03:46 PM |
i have used the puncture patches on gaiters and never been failed on it or ever picked up on it at the end of the day there is no hole and it isnt
leeaking grease
SteveWallace
posted on 23/5/17 at 03:12 PM |
I ended up replacing the gaiter just to be sure. However, the tester said that given where the hole was it would probably have only been an advisory
anyway. He said that he would have accepted sealant or an inner tube patch.
The car passed its MOT, which I was pleased about as it was its first official inspection after IVA three years ago.
