craigdiver
| posted on 13/8/17 at 02:14 PM |
Scuttle edging
Looking at starting to fabricate my scuttle, chassis is Haynes roadster / 442E hybrid so the glassfibre ones don't fit without cutting &
infilling.
Going to make my scuttle by making a frame and wrapping some 1.2mm Alu over it. This will leave an edge above the dashboard, will it be ok to use
safe-edge edging strip on this or will it need more radius for IVA?
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
mark chandler
| posted on 13/8/17 at 03:08 PM |
That's what I did
  Ali bulkhead
Cut some MDF formers for front and back, spaced out 8" then hand formed the aluminium over it.
In the picture you can see where I made it to deep at the sides so I could hold it secure with a couple of screws before I started to batter down the
edges.
craigdiver
| posted on 13/8/17 at 03:48 PM |
quote: Originally posted by mark chandler
That's what I did
  Ali bulkhead
edges.
Thanks Mark, I like the look of that - great job.
