Author: Subject: MOT - rear fog light
neilp1
posted on 15/8/17 at 01:28 PM Reply With Quote
1st mot coming up since getting car on road. So passed Iva with fog lamp wired up to relay so it didn't come back on when lights were switch back on. I have since removed this and wondered if I can wire it separate to the lights or does it have to come on only when dipped headlights are on.
Hope that made sense!!
ian locostzx9rc2
posted on 15/8/17 at 02:33 PM Reply With Quote
As per Iva as far as I'm aware
gingerprince
posted on 15/8/17 at 02:40 PM Reply With Quote
It can be separate: -
http://www.ukmot.com/manual/1.3/Rear-Fog-Lamps
Specifically: -
A rear fog lamp is permitted to operate independently of headlamp, position lamp or ignition systems.
gremlin1234
posted on 15/8/17 at 02:51 PM Reply With Quote
if its a Q reg, then you don't have to have to have rear fogs. however, I believe if fitted it must work
[Edited on 15/8/17 by gremlin1234]
neilp1
posted on 15/8/17 at 08:13 PM Reply With Quote
Specifically: -
Well after reading the above link I've wired up and it comes on with side/dipped headlights when switch to on position.
Thanks all
Neil
kingster996
posted on 16/8/17 at 07:23 AM Reply With Quote
Neil, the lads reckon Davy Bank is a good kit friendly MOT place by the way.
I used to be indecisive, but now I'm not so sure
neilp1
posted on 16/8/17 at 08:09 AM Reply With Quote
Cheers for that as that was my next question. I always used Tyne tyres for my last kit and found them ok.
