ArAKern
| posted on 20/8/17 at 02:57 PM |
Rear view camera IVA
In attempt to overcome the mirror issue I have decided to fit a camera.
one question should the screen be always on or only when reverse is selected?
could find nothing in section 08 indirect vision
except:- Camera systems will only be required to meet RS4, RS6 and RS12.
gremlin1234
| posted on 20/8/17 at 04:27 PM |
I would guess always on/(ignition on), since you look in the mirror as you drive.
certainly would wire it that way for iva
Bluemoon
| posted on 20/8/17 at 04:40 PM |
Unless the rules have changed (they might) you can't have CCTV set-up instead of a mirror... I would read the IVA manual...
adithorp
| posted on 20/8/17 at 06:06 PM |
Contact the IVA centre and ask. Runs in my mind though that Bluemoon is right.
http://jpsc.org.uk/forum/
gremlin1234
| posted on 20/8/17 at 07:39 PM |
quote: Unless the rules have changed (they might) you can't have CCTV set-up instead of a mirror... I would read the IVA manual...
Record of Revision (6)
03/10/2016 Incorporate camera systems, clarify Note 2 in Annexes 1 & 2
gremlin1234
| posted on 2/9/17 at 06:39 PM |
did you get anywhere with the camera installation?
ReMan
| posted on 3/9/17 at 08:07 AM |
Does that read that you CAN use a camera and monitor?
www.plusnine.co.uk
ArAKern
posted on 9/10/17 at 01:40 PM |
Sorry for the late reply test got canceled twice had to wait 8 weeks to get a slot.
Well according to the inspector only "type approved" camera are acceptable
he would not be drawn on the wording of the IVA manual ;-)
loggyboy
| posted on 9/10/17 at 02:05 PM |
I have just emailed DVSA to ask them to clarify.
'Could you advise on the use of reversing cameras on non type approved vehicles (ie kit cars)? Is it acceptable to use them in place of
mirrors?
Many Thanks etc etc'
Mistral Motorsport
ttalps2000
| posted on 9/10/17 at 02:52 PM |
"he would not be drawn on the wording of the IVA manual ;-)"
How unusual for IVA inspectors!!
gremlin1234
| posted on 9/10/17 at 06:38 PM |
I found this
https://www.unece.org/fileadmin/DAM/trans/main/wp29/wp29regs/2013/R046r5e.pdf
quote: Uniform provisions concerning the approval of devices for indirect
vision and of motor vehicles with regard to the installation of these
devices
loggyboy
| posted on 18/10/17 at 09:59 AM |
mirrors?
Got a response - first simply quoted the line in the manual, but I pushed for a more concise answer, and there is no need for camera system to be type
approved. So the inspector in question might need to review his stance.
Mistral Motorsport
ArAKern
| posted on 18/10/17 at 11:07 AM |
Just re-posting here if someone searches for cameras
Well Done LoggyBoy for getting the clarification.
So I was totally correct in my initial assumption
Just for reference I did not use a £30 cheepy reversing camera of ebay.
It was a Sony CCD effio-v (I use them for diy nightvision and FPV), I spent some time playing with different lenses
to get the best FOV (Field of View). if the fov is too wide you will see lots of distortion to narrow and you will not meet the requirements and
magnification becomes an issue.
The biggest compromise was the screen as I had limited space to mount it (did not fancy building a custom mount just for the test)
so ended up using a 5" with fairly low resolution in my opinion is was "just" good enough for the test would have much preferred a
7" -10" display...
If I was to do it again for real and as a total mirror replacement would go for full HD 1080p camera (minimum 720p) along with a 7" full HD
screen must be daylight view able high lux rating or one with a sun shield.
ttalps2000
| posted on 19/10/17 at 11:15 AM |
"So the inspector in question might need to review his stance"
Good luck!!
If you took it to a different station they would probably accept it with no issues at all!
cloudy
| posted on 14/4/20 at 03:18 PM |
Looks like they've added the requirement for approval back in. it now states:
CMS will only be required to meet RS4, RS6, RS12 and RS13
RS13: CMS must be approved to the requirements of UNECE Regulation 46.04
paragraph 6.2.2; documentary evidence will be required.
www.warnercars.com
coyoteboy
| posted on 14/4/20 at 05:41 PM |
They must get some guff bodge jobs in to be fair.
https://www.fixmystreet.com/
gremlin1234
| posted on 14/4/20 at 07:25 PM |
I saw that a while ago, and when I checked it relates to being able to see the screen in 'all lighting conditions'
cloudy
| posted on 14/4/20 at 09:45 PM |
Meaning they would accept something documented as having daylight readable attributes rather than certification docs? Did you get anything written to
back that up?
www.warnercars.com
gremlin1234
| posted on 16/4/20 at 02:23 PM |
I looked up secn 6.2.2
pages 16-18 in this document
https://www.unece.org/fileadmin/DAM/trans/main/wp29/wp29regs/R046r4e.pdf
both the camera and screen are tested, I wonder if there could be an 'approved' aftermarket kit
James
| posted on 17/4/20 at 12:57 PM |
What actually was "the mirror issue"?
I passed SVA with a MK2 Golf mirror that I 'pinched' off an abandoned Golf near me. It came with an SVA compliant rubber casing on the
shaft, but actually, once that was stripped off, underneath is a very nice cast ali shaft.
Guess things have changed a little since 2006!
- Muhammad Ali
