richardm6994
posted on 24/10/17 at 06:05 PM |
MOT steering wheel question
Looking at a vx220 that has popped up on Facebook.
As standard, the car originally had an airbag, but the owner has fitted an aftermarket steering wheel which has no airbag.
The car has a current MOT, but was wondering if the lack of airbag because of the aftermarket steering wheel would cause it to fail it’s next mot?
Airbag warning light also comes on but I’d image that’s easily fixed.
CosKev3
posted on 24/10/17 at 06:45 PM |
Test ; 1. As far as practicable, check that all airbags fitted as original equipment are present and not obviously defective.
Reason to fail; 1. An airbag obviously missing or defective.
That's copied from testers manual,so you are correct in thinking it will fail.
obfripper
posted on 24/10/17 at 06:46 PM |
It would fail for the airbag missing where fitted as standard, and for the airbag lamp indicating a fault.
Unless the car is fully rally prepared/msa logbooked there is no (legal) way around this.
Have a look at the criteria used for qualifing as a modified vehicle:
https://mattersoftesting.blog.gov.uk/when-is-a-modified-vehicle-a-rally-car/
It may be worth contacting your insurers to check if they would cover the vehicle with such a mod, some may and some definately will not.
Dave
gremlin1234
posted on 24/10/17 at 06:55 PM |
yep it should fail, the easiest thing to do is get an original steering wheel.
I would also recommend against just using the original for the mot. ie scrap the aftermarket wheel
perksy
posted on 24/10/17 at 07:59 PM |
Young lad at work had a 'modified' Peugeot, One of the Drum & Bassssss boys
Iirc he used to change the steering wheel back to standard for the MOT each year and had a link for stopping the warning light from coming on
I doubt it was covered by insurance, but then I doubt his lowered suspension was either
