WesBrooks
| posted on 4/1/18 at 08:34 PM |
Complications of American V8 in IVA?
Any one used an American V8 in an IVA recently?
Would simple written receipts be enough to support the list of where bits came from? How about proof of age? It's likely to be from a 1997-2005
age range and not pre-cat.
This would be an LS1. May consider the LT1 with the steel block. This is still the off-roader project and an autobox is still the preferred route.
This is just at the paper study stage. Considering a self built chassis so really need to nail down what I'm doing.
http://doctrucker.wordpress.com
hellblue
| posted on 13/1/18 at 08:53 AM |
There is a list of approved engine certifiers that is accepted for IVA, I think Real steel is one for American v8's obviously the engine will
need to meet its dated emissions, building your own chassis is not a problem just keep receipts and pictures
WesBrooks
| posted on 13/1/18 at 09:12 AM |
That's great thanks. So you don't need to worry about identity too much other than ensuring the code hasn't been ground off? Would
it be worth asking the supplier for VIN of the donour, reg etc or mot needed? I presume it's a charged service that those companies provive
rather than needing to buy from them?
[Edited on 13/1/18 by WesBrooks]
Slimy38
| posted on 13/1/18 at 12:47 PM |
I think it's two different things you're looking at. The first is the emissions range which is based on the engine age only, it
doesn't matter where it comes from. I'd expect that to be reasonably easily available, especially for something as well known as the LS1.
The donor information is only for registration, so if you use either new parts or donor parts you can get a plate that matches the donor. As a
comparison, my K reg MX5 donor is still lying in several boxes, and I'm reusing as much as I can to get a 1992 year plate.
As you don't have access to the donor for parts anyway, you wouldn't get a matching plate. So the options to you is a Q plate (which again
doesn't need donor information), or you can aim for a new plate by using all new parts apart from two that can be reconditioned (usually engine
and gearbox).
[Edited on 13/1/18 by Slimy38]
