Author: Subject: IVA Fog light - round?
mikeb
posted on 4/4/18 at 10:41 AM Reply With Quote
I need to replace my fog light (apparently its a brake light!)
Its like this one
https://www.ebay.co.uk/itm/Wipac-S6109-12-volt-Rear-FOG-light-lamp-COMPLETE-12v-12-v-NAS-universal/151350500298?_trkparms=aid%3D555017%26algo%3DPL.CAS SINI%26ao%3D1%26asc%3D20151016114640%26meid%3Dad91ae83daa84d2ebfadc050eecfa13e%26pid%3D100507%26rk%3D1%26rkt%3D1%26%26itm%3D151350500298&_trksid=p 2045573.c100507.m3226
ideally I would like something that would fit into the housing and have the same connector! Anyone found one?
mikeb
posted on 4/4/18 at 11:01 AM Reply With Quote
I've found this one
https://www.carbuildersolutions.com/uk/modern-style-95mm-fog-light-red-lens
can't quite make out if it has a F mark above the E?
tims31
posted on 4/4/18 at 11:04 AM Reply With Quote
Originally posted by mikeb
I've found this one
I have zoomed in and it looks like an 'F' but give them a call and make sure, normally very helpful and if its stated as a fog light then it should have the markings required
[Edited on 4/4/18 by tims31]
Build: http://www.martinsfurybuild.co.uk/
ttalps2000
posted on 4/4/18 at 12:16 PM Reply With Quote
Mine were never checked!!
loggyboy
posted on 4/4/18 at 12:33 PM Reply With Quote
His were - and failed on it.
Mistral Motorsport
furryeggs
posted on 4/4/18 at 12:35 PM Reply With Quote
If they are Jakon ones I think I have a spare lense/body.
mikeb
posted on 4/4/18 at 03:13 PM Reply With Quote
Mine were the standard wipac 90mm lights, I think I'll have to redo the connector anyhow so ideally want something that will fit in the current housing.
furryeggs
posted on 4/4/18 at 04:09 PM Reply With Quote
these are 90mm and look identical to the picture you put up, I’ll post a picture tonight. It looks the same. The bulb holder/connection should be universal.
CosKev3
posted on 4/4/18 at 04:46 PM Reply With Quote
I've found this one
The F denotes it's a fog light?
What's the difference between a brake light and a fog light out of interest?
mackei23b
posted on 4/4/18 at 05:38 PM Reply With Quote
I believe that the beam pattern is more focused on a fog lamp than on a brake light, so the lens is different.
Ian
CosKev3
posted on 4/4/18 at 05:44 PM Reply With Quote
Ian
Clear lense on these,so perhaps rear reflector is different?
mackei23b
posted on 4/4/18 at 05:48 PM Reply With Quote
Yes, that would also make sense.
Ian
