nick9one1
posted on 4/8/18 at 07:03 AM |
V627 Built up vehicle report
I have a question regarding the V627 (these probably aren't that common on this forum!)
There is a section to declare the major components, do all sections need to be completed or only enough to give the 8 points I need for a radically
altered vehicle?
I'm using unmodified chassis suspension and steering from the original vehicle, the engine is a zzr1100 and axles are cut&weld
VW/Freelander.
I dont have a receipt for anything other than the chassis. Does this matter?
russbost
posted on 4/8/18 at 09:41 AM |
I would put down as much as is reasonably conceivable as being correct, the more points you have the less possible reason for argument, for instance
when I register a bike engine car I still show transmission as coming from the Toyota donor as we use the Toyota diff & driveshafts which is most
definitely transmission. I wouldn't mention "cut & welded" if the axles can both conceivably go down as VW then that is what I
would put - the Freelander diff is irrelevant, when they say axles they are referring to what carries the wheels
nick9one1
posted on 4/8/18 at 09:53 AM |
Great thanks.
I'll fill out all the sections and list the axles as VW.
[Edited on 4/8/18 by nick9one1]
