tom225
posted on 14/11/19 at 09:57 PM |
Steering Column help!!
Hopeing some one with a little more knowledge of the IVA can help ( i have read it half a dozen times and still none the wiser on this bit).
Im building a Talon Motorsport chassis car, using the upper collapsible part of the MX5 column. Do I also require the 10deg kink in the steering shaft
or is the use of the collapsible part enough?
Thanks in advance.
Tom
Slimy38
posted on 15/11/19 at 07:01 AM |
quote: Originally posted by tom225
Thanks in advance.
Tom
I'm also using the Mx5 column, and I put the kink in the shaft. To be fair it's not difficult, by default it's about 8 degrees
anyway so it only needs a slight adjustment to deflect it further.
What I needed to fix
tom225
posted on 15/11/19 at 09:20 AM |
Thanks in advance.
Tom
I would agree it would be an easy fix, however i bought a partly completed build and its all installed already and will involve basically cutting
everything out and starting again for me, just seeing if i can avoid it.
Mr Whippy
posted on 15/11/19 at 12:18 PM |
post some pics and see if anyone can come up with a quick fix....
