aweekes1
posted on 27/1/05 at 07:19 PM |
SVA Documentation
Hi, I know you can send some money away for a hard copy SVA manual but can it be downloaded anywhere? (Legally)
I've seen draft copies for download but I can't use that for designing anything as it's not finalised.
Glan Noye
posted on 27/1/05 at 10:26 PM |
Try here http://www.pistonheads.com/gassing/topic.asp?t=53166&f=30&h=0
wicket
posted on 27/1/05 at 10:57 PM |
The link to the SVA manual does not work for me and in any case it will be out of date as the manual was revised in March 2004.
Buy your self a copy, its worth the money.
JonBowden
posted on 28/1/05 at 01:03 AM |
I've emailed you a draft copy in PDF format that I found somewhere
Jon
wicket
posted on 28/1/05 at 10:44 PM |
The only problem with the draft copy, if its the one from the VOSA, is its not the full manual, it only has the pages that show the proposed changes
that came into force March 2004.
Mark Allanson
posted on 28/1/05 at 11:05 PM |
I have the 2000 full copy and the 2004 amendments, I hope between the two I will be OK????
