jimmyjonga
| posted on 28/1/05 at 11:42 AM |
fuel cap in tank and sva??
hello there
do you think the sva man would have any problems if i just mount a fuel cap in the tank directly, rather than using an exterior mounted cap and some
filler hose???
realise might make luggage carring a bit of an issue, but happy to live with that..
james
chunkielad
| posted on 28/1/05 at 11:47 AM |
From reading the manual it appears to be a totally valid solution (I was looking at this too)
Plus if you have a lid on the back and it's locked, it's harder for those pesky vandals to nick petrol or 'drop' things into
the tank!!!Mainly because they won't know where the filler cap is!!!
| posted on 28/1/05 at 02:18 PM |
Mines a Mini filler neck welded on the tank and in the boot. As long as you use a proper cap it's o.k.
bob
| posted on 28/1/05 at 06:48 PM |
I passed ok with this cap under a locked boot,in fact i'm not even sure the locked boot is an issue as i had to remove my key locks for the
retest as they were not radiused enough.
nige
| posted on 29/1/05 at 06:18 PM |
fuel cap
bob
whats your cap make??????????????
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
bob
| posted on 29/1/05 at 07:10 PM |
The cap is a screw type made by MOCAL.
cost about £15 a couple of years back from here www.thinkauto.com
givemethebighammer
| posted on 29/1/05 at 07:22 PM |
A few weeks from SVA but my filler is mounted in the top of the tank. It’s a motorbike type unit from Rally Design (lockable). Bryn at Allyfab fitted
it for me when he made the tank. There is also an unleaded fuel nozzle restrictor (which I now realise I don't need) in the bottom of the
filler.
