Slimy38
posted on 20/2/24 at 08:30 AM |
Right angle edge protection
In my interior I have some sharp ninety degree corners where aluminium sheets meet. I'm looking for some black edge trim to go over the corners
to make them IVA friendly and look a bit tidier. Unfortunately as with everything internet based I'm struggling with what to Google for. I
started with Car Builder Solutions and Woolies, neither of them seem to sell an outside right angle trim. Woolies did give me a hint though, what
material should it be? I assumed rubber?
Can anyone suggest what I should be searching for, then hopefully I can find a source.
gremlin1234
posted on 20/2/24 at 08:58 AM |
this is probably far too big but may give you some ideas
rubber corner protector
https://www.seton.co.uk/rubber-corner-protector.html
edit to add
https://startsafety.uk/barriers/wall-protectors/white-foam-edge-protectors
[Edited on 20/2/24 by gremlin1234]
Slimy38
posted on 20/2/24 at 09:25 AM |
edit to add
That's the sort of thing I'm after, but £100 for 2.4m is obscene. Is that really how much it would cost?
The white foam one actually made me laugh, it's huge!! If I put it on either side of the transmission tunnel I don't think I'd be able
to select reverse or fifth on the shifter!!
cliftyhanger
posted on 20/2/24 at 10:36 AM |
https://coh-baines.co.uk/collections/l-profiles
Baines are really good, I think they supply many others in the trade.
Mr Whippy
posted on 20/2/24 at 11:09 AM |
you could just get some plastic 90 channel section from B&Q
40inches
posted on 20/2/24 at 11:20 AM |
It doesn't have to be rubber, aluminium Cope Mouldings will do the job,
https://www.aluminiumwarehouse.co.uk/collections/aluminium-mouldings-cope/products/aluminium-cope-moulding-awcp1016?variant=42359885004988
As here:
Side Repeaters
peter030371
posted on 20/2/24 at 11:59 AM |
Is it just for the transmission tunnel? I used some aluminium profile to go over the bare carbon edges on mine. It has a large radius which feels fine
on the arms although I didn't need to IVA this car as it was already registered under SVA and I was just refurbishing some of it.
carbon tunnel trim
inside
Can't remember the exact profile I used but it was something like this.
https://www.aluminium-online.co.uk/product/aluminium-architectural-section-la206/?attribute_pa_length=600mm&gad_source=1&gclid=CjwKCAiAuNGuBhA
kEiwAGId4atml_9O9Q4kaKOB5dfsM3j2uidosk8j7MY_Xa5rtj8O9EHekRKcOlBoCN5IQAvD_BwE
gremlin1234
posted on 20/2/24 at 01:28 PM |
if its for the tunnel, you could cover it with nylon carpet
gremlin1234
posted on 20/2/24 at 01:40 PM |
this could also work
https://www.cayrus.co.uk/product/aluminium-retro-fit-tile-trim-angle-edge-protector-cladding-corner-trim-20x20mm/
posted on 20/2/24 at 02:45 PM |
If it's the edges of your tunnel, I had the same issue for my SVA and used rubber tadpole trim bonded to the underside of the tunnel top
panels.
https://georgeculley.co.uk/products/black-epdm-rubber-ta
dpole-4mm-dia-ball-x-16-mm-blade
Cheap and easy to do, got through the SVA and looked reasonable enough to just leave in place afterwards.
https://www.carbuilder.com/uk/wing-piping-55mm-dia-x-38mm
[Edited on 20-2-24 by nick205]
Mr Whippy
posted on 20/2/24 at 03:25 PM |
Although, nothing beats a nice padded interior
posted on 20/2/24 at 03:37 PM |
In my tin top for everyday trudging - fair comment.
In my kit car for generally shorter trips (when I'm quite happy to dress appropriately) - just the basics will do for me.
My MK Indy (no roof, no windscreen, no sidescreens) got a couple of rain soakings. Basic unpadded interior dries out far faster and suffers far less.
Slimy38
It's for the tunnel and for the outside edge. Here's the interior with the aluminium panels shaped but not rivetted;
That rules out carpet as it would have to be everywhere and I want to keep as much exposed aluminium as possible. I do quite like the idea of
aluminium on aluminium though. I was going to go for a contrast black plastic or rubber, but a nicely finished (even slightly different grade) metal
edge would work.
posted on 20/2/24 at 04:24 PM |
Agree - Ally interior is good.
42983[/pg]]
My tunnel top was removable (held down with dome head cap screws).
The rest was bare Ally, except the sides where it was the inner faces of the GRP.
jacko
posted on 20/2/24 at 05:09 PM |
You need to search for hockey stick aluminium
555
ianhurley20
posted on 21/2/24 at 10:22 PM |
panels.
Different suppliers but almost exactly what I did!
