bigandy
posted on 13/2/05 at 10:20 AM |
Where does mr SVA stand on Flexible brake lines?
Morning all,
I was just wondering where MR SVA man stands on flexible brake lines? Is he of the opinion that they should not touch anything other than the fixings
at both ends? Or would he consider them to be okay if affixed to the suspension arms at regular intervals?
I'm just trying to decide how to fix them in place at the moment. I can understand the need to avoid the lines chafing on anything, but if they
are unsupported, then they could flap all over the place surely?
Dammit! Too many decisions....
| posted on 13/2/05 at 10:25 AM |
Some cars like V.W. polo's have rubber rings around the brake flexi's that attach to brackets on suspension to secure them , may be worth
a look?
Snuggs
| posted on 13/2/05 at 10:59 AM |
Flexible brake lines must not snag, rub or chaff on anything but they also must not flap about .
I used plastic P clips bolted together to secure them to the wishbones.
Large P for the wishbone and a small P for the pipe. A strip of metal or plastic between the clips can be used to extend or change the angle.
Hope this makes sense.
Clive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
bigandy
| posted on 13/2/05 at 11:31 AM |
a doubled up P-clip! That's a cracking idea!
To be honest, I wasn't sure about clipping the flexi lines straight to the wishbone, as I'm sure it could rub slightly (and eventually
wear through something!). My front brakes only have a short run, so I might be able to get away with no clips at all there, but the rears are about
twice as long.
Cheers!
RazMan
| posted on 13/2/05 at 11:01 PM |
I'm using Goodrich braided jobbies. Mine are secured with P clips to the trailing link arms on the rear and to the lower wishbone on the front I
hope it's ok.
Raz
| posted on 14/2/05 at 06:45 PM |
i left mine unsupported and spent a while adjusting the brackets (mallet!) to ensure it didnt touch anything from lock to lock. However, i wouldnt be
suprised if it did fail for flapping about...
| posted on 14/2/05 at 07:35 PM |
Mine touched my front wing bracket very slightly so I put some rubber hose round it and it passed.
subk2002
| posted on 14/2/05 at 10:12 PM |
At my sva the guy told me to ti-wrap it to the rear wishbone then passed me
He said it was hanging to low
