Humbug
posted on 15/2/05 at 11:22 AM |
Indicators on top of cycle wings
Has anyone done this? I think from SVA point of view they should be nice and visible, and I maybe something like old VW beetle front indicators could
look quite good. Wiring would be a minor issue to get it looking tidy, I s'pose.
My ST has holes on the headlamp brackets for round mini-type indicators but I think they are more than 400mm inboard of the rear wings.
ned
posted on 15/2/05 at 11:32 AM |
surreydave has done this iirc..
Ned.
beware, I've got yellow skin
DarrenW
posted on 15/2/05 at 12:14 PM |
Mac#1 have just started to do them. Look very nice - about £14 pair iirc. Hasnt Caterham or Westfield done this for some time now?
The SVA manual also says that you dont need a dash tell tale if you can see the indicators from the drivers seating position (check it for yourself
tho'
James
posted on 15/2/05 at 02:12 PM |
There is a slight disadvantage that you're adding more weight to something that is already notorious for breaking!
Not a lot of weight of course but it might be enough to tip the balance.
James
mangogrooveworkshop
posted on 15/2/05 at 03:55 PM |
Better to use leds in this lamp set as the vibrations with stuff the lamp filiments.
As the man says these things fall off, but as a plus they will remain tethered to the car dragging along when they do break
Jon Ison
posted on 15/2/05 at 07:55 PM |
thats what i used, u can see them in this pic, more in archive too.....
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=GTRRRRR%20010.jpg
there stick on too, just one small hole for wires.....
[Edited on 15/2/05 by Jon Ison]
