Author: Subject: Twin Headlights
James
posted on 17/3/05 at 04:39 PM Reply With Quote
Twin Headlights
Can anyone think of a SVA/MOT reason not to put two pairs of smaller headlights at the front? Assuming the radiuses were fine?
They would be rigged to act as one.
James
*And yes, I do realise I'd be paying to add weight to the car!
[Edited on 17/3/05 by James]
Mix
posted on 17/3/05 at 04:58 PM Reply With Quote
This is something that has crossed my mind.
Is it permissable to have separate units for dip and main beams?
Mick
Kitlooney1000
posted on 17/3/05 at 05:03 PM Reply With Quote
If i remember right, you are allowed two of eac light on each side of the car, Headlights dipped and high beam and sidelights, but you might want to check an SVA manual
Doesnt matter what Sh*t life throws at you, there is always some other poor bugger worse off!!!!!
posted on 17/3/05 at 05:19 PM Reply With Quote
Only 2 dipped beams allowed main beam is usually all four.
Dipped beams should be on the outside -- at least that is how I remember it.
RoadkillUK
posted on 17/3/05 at 07:03 PM Reply With Quote
My Xantia has 2 dipped and 4 main beam. HTH
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
Mix
posted on 18/3/05 at 07:44 AM Reply With Quote
OK, so now the $64,000 question.
How do we think Mr SVA would would view such a set up and would he take his measurements only from the outside of the outer lens? (assuming the lights to be mounted in horizontal pairs).
Or, even better, has anyone passed with a configuration similar?
Mick
posted on 18/3/05 at 08:21 AM Reply With Quote
Well, if the dippable ones are on the outside, then I guess he'd measure to there - that's the light that would always be on when the headlamps are lit.
