carlgeldard
| posted on 2/4/05 at 05:16 PM |
Calling all pinto owner/drivers
Hi All
I am just about ready for the SVA and I would like to check the speedo. So could you tell me how fast the speedo says you are going in second gear at
2000rpm. Any indication would help as I can fine tune at SVA. I am running a 2lt pinto type9 box and serria diff.
Thanks Carl (SVA Very soon)
theconrodkid
| posted on 2/4/05 at 06:54 PM |
i did mine in top,40 is about 2000 and 60 about 3000,that should get you near enough with standard size tyres
who cares who wins
pass the pork pies
Mr G
| posted on 2/4/05 at 06:56 PM |
I think you'll find there are a few variables.
wheel/tyre diameter
diff ratio
Amount of teeth on output shaft teeth gear/speedo drive.
G
Mark Allanson
| posted on 2/4/05 at 07:47 PM |
This may help
| posted on 2/4/05 at 09:56 PM |
the speedo reads of the gearbox usually, so changing diff and wheels wont affect the reading related to revs, only what the real speed is at any given
revs. If in doubt, put in a 3.9 diff for the test - you are allowed to read too high i believe.
carlgeldard
| posted on 4/4/05 at 07:34 AM |
Thanks that spreedsheet is just what I need.
Thanks Carl
