Author: Subject: Cam shaft identification
JohnFol
posted on 15/11/02 at 08:42 AM Reply With Quote
Just got the GT cam through the post, and am not sure it's correct. Is there anyway to be able to tell if it's a 1300 GT cam, or an 1100, 1600 etc. . . ??
Haynes mentions colour combinations, however the one I have removed has no colour on it, whereas the new one has some red on it. This doesn't mean there was or was not whie as well . . .
any ideas?
jollygreengiant
posted on 15/11/02 at 01:26 PM Reply With Quote
cam identification
Sorry but unless your cam came from the dealers then there is very little to tell you what spec your cam is. The only easy cams to identify use to be pinto cams.
1 dimple on the shaft was 1.6, 2 dimples was 1.6gt/2.0. Other than that you you come down to measuring base circle, total lift, duration of lift, timing over lap,start and finish angles of lift and then you get out the refernce books and start working it out manually according to the spec for each grade of camshaft.
1.3std
1.3gt
1.3fast road
etc
etc and then you ve got the odd special home grinder/local specialist lobe profiles.
JohnFol
posted on 15/11/02 at 03:58 PM Reply With Quote
There are several markings on the shaft to indicate the part number. What I don't have is a way of interpreting or comparing them with other known shafts.
Does anyone have a GT / 1600 shaft out of an engine at the moment?
theconrodkid
posted on 15/11/02 at 05:36 PM Reply With Quote
mail bob he has a mountain of engine bits in his garage
bob
posted on 15/11/02 at 07:02 PM Reply With Quote
Yeah but my mountain of eng bits are all pinto,as JJG said earlier they are easy to ID.
The only info i have on x/flow cams regarding coding is any yellow on cam and its 1.3 LC or HC red and white is 1.3 2V and red is 1.6 2V.
This info is taken from another site,so its only as good as the person who posted in other words who knows.
John
I'd phone vulcan engineering as they would deffinatly know for sure.
locodude
posted on 15/11/02 at 07:10 PM Reply With Quote
If it's a Kent cam then the marking is stamped on the flywheel end of the cam. Not sure about other makes!
JohnFol
posted on 18/11/02 at 08:13 AM Reply With Quote
locodude, given the markings, can anyone translate them to which engine the cam came from?
david walker
posted on 18/11/02 at 10:15 PM Reply With Quote
Chris is referring to modified/performance cams produced by such companies as Kent or Piper, not Ford originals.
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
david walker
posted on 18/11/02 at 10:16 PM Reply With Quote
JohnFol
posted on 19/11/02 at 08:50 AM Reply With Quote
Agreed, but the comment still holds true.
the marking (inus the year stuff) is
6250 (meaning its a cam) followed by CC
there is an 8 and B either side if the gear tooth followed by these
16 H I
Any ideas?
darryl beckwith
posted on 19/11/02 at 09:20 PM Reply With Quote
Hi john
if you have a ford cam and the number on it is
771m 6250ca it is a 1300GT
771m6250ba it is a 1600GT.
be carfull as there are some long duration cams being used in the championship.which are not legal (in the locost championship)
hope this helps
darryl
JohnFol
posted on 20/11/02 at 08:43 AM Reply With Quote
Yes this is a ford cam. My original starts of 701M, and the replacement starts 71F (or poss 711F - bit hard to tell) I understood this gives year of manufacture and original model it was fitted to.
The site I got that info from suggests the letter suffix is the revision, so is a 6250 CC a 3rd generation CA 1300GT cam?
Daryl, do you know what the scrutineers look for?
Regards
darryl beckwith
posted on 20/11/02 at 08:34 PM Reply With Quote
Hi again
This year they did not check them but my understanding is that they will be checking next year. They will be looking at lift at various degrees of rotation. If that does not meet with the information they have they will remove the cams and have them checked by Kent cams. As I said some people have been using long duration cams with 300 degree duration rather than 272 which is standard on a GT cam. This would give you about 8 bhp advantage over a standard GT cam. If you are going to race in the championship and cannot be 100% certain that you have the right lift and duration then I would buy a Kent 103/4 as I think the club is serious about checking them.
All the best, hope to see you next year. If I can be of any more help, email me off list
Thanks Darryl (one of the drivers committee)
Deckman001
posted on 20/11/02 at 08:52 PM Reply With Quote
Hi Darryl, I'm trying to build a car for next season, but wont be ready till at least half way through season now. These cam checks you talk about, obviously i've no intention of cheating and hope no-one else has(i might be too naive for this game) but I havn't built my own engine so wouldn't know how to remove/refit bits like that, what sort of degree of help would the scrutineers provide for this type of check ?
Jason
[Edited on 11/20/02 by Deckman001]
darryl beckwith
posted on 20/11/02 at 09:18 PM Reply With Quote
Hi
good question that......the way it works is that the engine would be sealed at the meeting and at a time and place of your convenience a scrutineer would watch it being removed and take it away. I would expect my engine builder to do it for free. If the cam was ok the club would pay reasonable rebuild costs. If it was not ok the cost is down to you
all the best
Darryl
JohnFol
posted on 21/11/02 at 09:26 AM Reply With Quote
Just got through to someone at Ford (who is 100 times more helpfull than matey yesterday)
Here's the deal.
701M 6250 cc is from my original 1300 engine (car is a GL not GT)
711F 6250 cc is from a 1600 (which is what 'specialist' sent me)
Darryl is 100% correct with 771M 6250 ca being from the 1300 GT.
Many thanks to all those who have helped.
PS Would it be a good idea to collate some of thse things? I remember the hassle I had identifying which carbs are race legal ... .. .
Deckman001
posted on 21/11/02 at 10:10 AM Reply With Quote
Thanks Darryl,
Clears it up a bit, unfortunately for me I bought mine from a guy who changed his mind about which series he was going to race in, so looks like i've got to learn abit quick !
