Author: Subject: SVA Form again
Hornet
posted on 25/4/05 at 09:00 PM Reply With Quote
SVA Form again
Gents, desperate to post the application form tomorrow.... Can you help with the following questions?
Question2: Vehicle Make?
Question3: Full model Description?
Question15: Axle weights (Got car weighed today)
Actual results = Front 300kgs Rear 290kgs.. What should I put on form? Was thinking 400kgs front 400 kgs rear?
Cheers in advance
posted on 26/4/05 at 07:14 AM Reply With Quote
If you made the car entirely yourself, then
Q2: Whatever you want
Q3: Whatever you want
If you've made a kit (MK or whatever) then you may have to put that name down.
Might be worth clearing it with the local DVLA man. As mine was built from scratch, I called it a Lathyrus 7 - don't ask why - it's a longish story!.
Q15: 400kgs sounds OK - you'll get a chance to correct it at the test if you're too far wrong.
Good luck!
