shortie
posted on 22/6/05 at 07:42 AM |
Headlights
Just wondering how others have aligned their headlights?
I am going to get it MOT'd before the SVA so is is best to make sure they are correct then?
Rich.
jimgiblett
posted on 22/6/05 at 08:10 AM |
Get them roughly right against a wall or garage door then fiddle with them at the MOT centre.
Even though I did this I had to do another minor adjustment at SVA.
posted on 22/6/05 at 04:17 PM |
Mark out the beam pattern of your typical road car and copy this. That's what we did and the MOT guy commented as to how we did it.
shortie
posted on 22/6/05 at 08:36 PM |
Might be a stupid question but how do I do that!!?
Rich.
welderman
Same as Hellfire, but my markings go up and down. (they are on the roller shutter door at work).
posted on 22/6/05 at 09:22 PM |
Stick tintops lights on garage door and mark out top of beam with some tape. Also mark position of front wheels on drive. Then basically replicate
position of lights on Indy to those on garage door. Job done.
welderman
posted on 22/6/05 at 09:36 PM |
Your more than welcome to borrow our roller shutter door.
Yep same as Hellfire again. And one light was spot on and the other only needed moving a bugs d--k
smart51
posted on 22/6/05 at 09:43 PM |
don't the headlights of your "normal" car and your seven have to be at the same height for this to work?
Mark Allanson
Nobody likes a smart arse!!!!
Mark Allanson
posted on 22/6/05 at 09:48 PM |
Seriously though, find a good bit of ground with a straight wall. Use a tape measure to read the height of the centre of the headlamp, adjust the
headlamp to get the beam 2" less than the lens centre height at a distance of 10' away
