Author: Subject: filling out sva application for my MK indy
john_p_b
posted on 13/7/05 at 04:30 PM Reply With Quote
hi guys, i've finally got to that point of applying for test but am a bit stuck with a few bits of the form.
my donor was a 1984 2.0 sierra
maximum road speed? i'm pretty sure they were something like 107mph for the sierra running a 2.0 pinto but can anyone give me a better idea?
maximum power engine speed rpm? again unsure what a 2.0 pinto revs up to, i know my cosworth goes to 7k and beyond but a standard pinto i don't know?
design weights of the vehicle? axle 1: and axle 2: in KG any ideas anyone? it's pretty basic inside, plastic side trims, fibreglass seats and a roughly 6gl fuel tank in the back.
i know i may be pushing my luck with the above but i'd be very gratefull for any help.
cheers
john
posted on 13/7/05 at 04:52 PM Reply With Quote
They use the maximum road speed to check the tyre ratings, so go for 110mph if your tyre ratings are up to it.
Maximum revs they use to test noise at 75% so aim low. Go for about 5,000
Axle 1 design weight 400kg. Axle 2 - 500kg
HTH
posted on 13/7/05 at 05:31 PM Reply With Quote
I told them it runs up to 5,000 rpm at Derby and they told me they test pintos at 4,000 rpm, 2/3 of 6000 rpm . They accepted my 100mph top speed though.
bob
posted on 13/7/05 at 05:47 PM Reply With Quote
I put 100mph and that was fine with mitcham station,i put engine revs at 4500 and the examiner tested me at 4000 as pete.
axle weight i put axle 1 at 350kg and axle 2 at 300kg but if its wrong they change it anyway.
Mark Allanson
posted on 13/7/05 at 10:58 PM Reply With Quote
I put 100mph on my form, Terry at Exeter SVA called me a lying bastard, laughed outloud, checked the tyre ratings, laughed again and passed me
john_p_b
posted on 14/7/05 at 08:25 PM Reply With Quote
thanks for all the help folks, i've almost got it sorted now!
just one last question!
on the form it's got:
Q2 vehicle make. that one easy enough
but
Q3 full model description? that one i'm not sure about!
anyone?
posted on 14/7/05 at 09:24 PM Reply With Quote
Q2 - MK
Q3 - Indy
john_p_b
posted on 15/7/05 at 04:36 PM Reply With Quote
easy as that?!
thanks hellfire, i thought it might have been that but it seemed too simple!
cheers guys for all the help
