Author: Subject: SVA Failure
shortie
posted on 18/7/05 at 02:05 PM Reply With Quote
SVA Failure
Well had the SVA today and all in all quite pleased with the rseult even if it did fail.
Was perfect on everything apart from noise
104.8db so I need to get it down to 101, am going to put a baffle in and have changed the can to a 907 can that Deckman VERY kindly leant me.
Back again at 8am in the morning so fingers crossed!
Many many thanks to Donut, Deckman and GasGasGas for coming along and helping.
Rich.
scoobyis2cool
posted on 18/7/05 at 02:07 PM Reply With Quote
Bad luck on the failure but only one fail point is a highly impressive result! Hope you get it all sorted in plenty of time, good luck for the retest
Pete
Fozzie
posted on 18/7/05 at 02:15 PM Reply With Quote
Well Rich, I think you did brilliantly!
The only 'downside' was the noise, but your actual build passed! that in itself is most exellent!...well done!
IIRC Jasper had the same problem with his bec at Mitcham.
Fingers crossed for the noise levels in t'morning!
ATB fozzie
shortie
posted on 18/7/05 at 02:19 PM Reply With Quote
you were right Chris!!
DO you think I should use the 907 can with a baffle or stick with the MK one with baffle for the test?
Rich.
ReMan
posted on 18/7/05 at 02:35 PM Reply With Quote
Nice one.
I'd consider that an excellent result.
Not having to strip the body off or rewire it again has got to be good!
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
donut
posted on 18/7/05 at 02:37 PM Reply With Quote
Hi Rich
Yeah bad luck that but with a little fettling i'm sure you can get it sorted.
it was an inspiration to see your car as it's the dogs and i have ordered my bike engine so i'll be close behind you!!!
Good luck for tomorrow.
ned
posted on 18/7/05 at 03:10 PM Reply With Quote
what are you doing now andy?
Ned.
beware, I've got yellow skin
James
posted on 18/7/05 at 03:46 PM Reply With Quote
Sweet Jesus! Hope it's from a Goldwing!
Shortie,
Well done on such a 'good' failure- should be easy to sort out.
Hope we'll see you and it up at Newlands a bit now!
James
GeoffT
posted on 18/7/05 at 04:01 PM Reply With Quote
Hi Rich,
My car also failed initially on noise level, I managed to borrow a dB meter to set it up before the retest. One thing I did discover was that the exit direction of the exhaust tailpipe made a LOT of difference to the noise level as perceived by the meter. Worst case was pointing straight down onto the road, best, surprisingly enough, was pointing straight out sideways towards the meter. I managed to loose 2-3 dB this way.
Not sure if the 907 cans allow you swivel the outlet, if they do it's something else you can try if you get a problem tomorrow. Good luck anyway.
shortie
posted on 18/7/05 at 04:09 PM Reply With Quote
Well it was pointing straight out and with a baffle I got it down to between 86-98db.
After speaking to MAC1 I have now pointed it more or less straight down but reading the last post who knows!!
Well we will find out tommorrow I guess!
Rich.
P.S. Thinking about it I could point it under the car I guess!
[Edited on 18/7/05 by shortie]
Deckman001
posted on 18/7/05 at 04:38 PM Reply With Quote
Test it at both angles, see what's best on your meter
Jason
shortie
posted on 18/7/05 at 05:14 PM Reply With Quote
getting a bit late now though!!
Think I will just point it out sideways and slightly down and hope for the best.
Rich.
Deckman001
posted on 18/7/05 at 05:25 PM Reply With Quote
How about we get there a bit early and try it then ?
Jason
bob
posted on 18/7/05 at 06:03 PM Reply With Quote
Well done rich,in my book thats a pass
At what revs did we test it at with the maplin noise reader ?
shortie
posted on 18/7/05 at 06:54 PM Reply With Quote
u2u sent Deckman. Rich.
shortie
posted on 18/7/05 at 06:58 PM Reply With Quote
Bob,
We tested it at 6000 but we should have done 6750.
Rich.
Deckman001
posted on 19/7/05 at 08:23 AM Reply With Quote
ned
posted on 19/7/05 at 08:47 AM Reply With Quote
sounds like good news
Deckman001
posted on 19/7/05 at 08:51 AM Reply With Quote
He He He
A 907 can strikes again !
Jason
donut
posted on 19/7/05 at 08:56 AM Reply With Quote
James you are such a cheeky ass
