Jasper
| posted on 20/8/05 at 02:43 PM |
New reg - worth going for?
The new part built car I have has been built so far using all new parts (except Sierra column and switch gear). Is it worth me continuing this route?
The only other non-new part will probbably be engine/box.
Is it worth going for a new reg, rather than a 'Q'. I realise a new plate will be more desirable if I sell, but will it cause problems for
future MOT's? I presume I will have to pass more stringent emissions every year. Anything else that is for or against? And How many non-new
parts can I have and still get a 'new plate'?
| posted on 20/8/05 at 05:44 PM |
AFAIK all parts must be new or reconditioned to an as new standard. This might just involve a lick of paint though
not sure where you would stand with emissions though.
indykid
| posted on 20/8/05 at 11:16 PM |
i thought only one major item could be reconditioned of any description.
if you go bec, surely transmission only includes prop, diff and halfshafts
tom
DavidM
| posted on 21/8/05 at 02:45 PM |
To be registered as a new vehicle the car must use not more than one reconditioned component, but evidence must be available that the component is to
an "as new" standard.
My reading of the leaflet I've just received from DVLA is that you also have to provide a certificate/evidence of "newness" of other
components used.
Hope this helps,
Proportion is Everything
wicket
| posted on 21/8/05 at 07:25 PM |
Information here Jasper
http://www.totalkitcar.com/tkc_article_124.php
don't know how accurate it is but it does have links to DVLA sites.
Its good to see you back in build mode !
Eric
Jasper
| posted on 21/8/05 at 08:13 PM |
Cheers chaps - think I'll stick with a Q so I never need worry about emissions...
Marcus
| posted on 22/8/05 at 08:27 PM |
Was reading another forum recently, a guy on there was an MOT tester, and says that a Kit or amateur built vehicle will only ever be tested for
visible smoke at emissions. Any idea how true this is, I thought it was based on donor age?
Marcus
Marcus
Because kits are for girls!!
| posted on 22/8/05 at 08:58 PM |
AFAIK, its only Qs that get the visible smoke test, all others are tested as age related. maybe he assumed that all kits end up on a Q?
[Edited on 22/8/05 by JoelP]
| posted on 22/8/05 at 11:53 PM |
They've never used the sensor on my 'E' reg kit car but they used to on my Escort so I reckon they only use the visible smoke test
at my local garage
ned
| posted on 23/8/05 at 10:40 AM |
re: new parts, reconoditioning and receipts, what were computers invented for eh?
beware, I've got yellow skin
