andybod
| posted on 27/8/05 at 04:24 AM |
dash warning lamps
help please for the sva do the tell tale warning lamps have to have the correct symbols on them i.e brake levels/handbake, indicators, main beam
e.t.c or are correctly coloured lights and labels ok
Avoneer
| posted on 27/8/05 at 07:12 AM |
Brake Level / Handbrake has to be labelled on the light itself and I'm pretty sure Hazard one does as well.
Pat...
wilkingj
| posted on 27/8/05 at 07:15 AM |
Basically YES
I have used the Bright6 module, very neat, easy to wire up, and can bee seen even in daylight (needed for SVA as well).
Bit pricey, but worth it.
Bright 6 Website
You can get a dimming kit for £1.99 as well.. if you dont want it bright at night.
Best Regards
Geoff
http://www.v8viento.co.uk
| posted on 27/8/05 at 07:17 AM |
If you have a light with the correct symbol 'built-in', e.g. the Bright6 module, then you don't need a label. In fact, I think the
brake warning light is the only one that needs to have the correct symbol on it. ((!))
The hazard warning switch also needs the correct symbol - the double white triangle, usually on red (I think!)
tom_loughlin
| posted on 27/8/05 at 09:19 AM |
My only problem wit the bright6 is that there is no fog light warning lamp on it.
Made my own out of an LED set i got from ebay.
Tom
jonbeedle
| posted on 27/8/05 at 10:22 AM |
I've just got coloured lights. I was going to put a label under the brake warning light. Is that not good enough?
Cheers Jon
"Everyone is entitled to an opinion however stupid!"
| posted on 27/8/05 at 12:05 PM |
You need one or the other on the light itself
[Edited on 27-8-05 by Hellfire]
jonbeedle
| posted on 27/8/05 at 12:26 PM |
Oh tits!
Steve @ sVc
| posted on 2/9/05 at 11:53 AM |
We have SVA correct dash lights with brake marking on for £4 each (we supply most of the "7" companies with these).
Hazard warning light generally built into the switch, but we have the single lights marked for hazard warning, again for £4 (and many other
symbols).
Regards
Steve @ sVc
