planetester
posted on 9/9/05 at 07:20 PM |
fuel tanks
Has anyone ever rivetted a fuel tank instead of welding all the bits together,
aircraft are built like this, so does it need to be welded
thanks all
mangogrooveworkshop
posted on 9/9/05 at 07:50 PM |
There was one lad a while back who did that.
Cant remember how far back in 2003 .
DaveFJ
posted on 9/9/05 at 09:19 PM |
Aircraft generally use rubber fuel cells inside riveted compartments. I think it would be extremely difficult to make a leak proof riveted tank.
Dave
posted on 9/9/05 at 09:55 PM |
It was done yes...
It's being done all the time... click >>X<< to see it being done and
what to use etc etc
HTH
planetester
posted on 9/9/05 at 10:11 PM |
thanks mangogrooveworkshop, I found it at http://www.locostbuilders.co.uk/viewthread.php?tid=12412, mine looks similat to his except I have folded the
flanges on the end panels outward so they are not in the fuel, & I have used the 1422 sealant from work,
BUT WHAT WILL THE SVA MAN SAY
posted on 9/9/05 at 10:16 PM |
If he questions it - just advise him how unreliable plastic tanks have been, it can't be any worse than that can it? If it's tested not
to leak that's all you can do...
RazMan
posted on 17/9/05 at 03:21 PM |
I would have thought the riveted joints would be prone to leaking after some time and vibration have done their worst. For security I would stick to
welding - at least you know it is not going to let you down.
Raz
