dhollin3
| posted on 21/10/05 at 08:21 AM |
Horn
Does anyone know where the horn needs to be located to pass the SVA. Does it have to be on the steering wheel, dash or just within easy reach?
Snuggs
| posted on 21/10/05 at 08:28 AM |
AFAIK
The horn is not tested at SVA but it is required for MOT.
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
dhollin3
| posted on 21/10/05 at 08:31 AM |
Does it have to be located in a certain position for an MOT?
Snuggs
| posted on 21/10/05 at 08:32 AM |
For MOT I think that it just has to work.
zzrpowerd-locost
| posted on 21/10/05 at 08:44 AM |
on the steering wheel???? would deafen you every time you gave it a honk!
would say somewhere inside the nose cone would be suitable!
flak monkey
| posted on 21/10/05 at 08:46 AM |
I belive that the horn needs ot be functional for the SVA, and it must also work without the ignition on.
I could be wrong though.
Sera
http://www.motosera.com
| posted on 21/10/05 at 09:25 AM |
My horn was tested during the SVA - scared the life out of the tester! (twin FIAMM air horns).
barrie sharp
| posted on 21/10/05 at 09:35 AM |
my horn button is on the centre tunnel just below the gear stick
Passed sva and mot like it
Hope this helps Barrie
the cars looking good" a blind man would be pleased to see it"
''stop press'' the blind mans seen it said "it felt ok"
Humbug
| posted on 21/10/05 at 09:39 AM |
Horn is not mentioned in the SVA manual AFAIK. I have read somewhere else that you do not need a horn fitted for SVA.
Having said that, my SVA tester did test the horn - air horns make a nice loud noise in the SVA lane of the test "hangar" at Gillingham
coovey
| posted on 21/10/05 at 10:16 AM |
Horn, is 100% not tested for SVA. Mine decided to drop a wire 5 mins before the sva so we had a panic to get it fixed. Got it fixed and apologised for
being a minute late and was told I shouldn't have bothered cause horn is not required for SVA
shortie
| posted on 21/10/05 at 10:35 AM |
Horn is def NOT tested for SVA and not required.
But I guess as you need it for an MOT in the future and it's worth having anyway then why not fit it anyway. Doesn't matter where the
button is located, mines on the dash centre console bit.
Rich.
donut
| posted on 21/10/05 at 10:51 AM |
I fitted my horn just behind the Rad as per 'A Race Car Is Born' Westfield build on TV. I don't think it matters where it goes but
under the bonnet/nose cone & out of the way would be good.
