Author: Subject: Towing dolly
jonbeedle
posted on 23/11/05 at 11:21 PM Reply With Quote
Towing dolly
Can't afford a car trailer at the moment. Is it legal to use a towing dolly and are they expensive and do they fit any car or do I need a special one for a Locost?
Jon
"Everyone is entitled to an opinion however stupid!"
owelly
posted on 23/11/05 at 11:53 PM Reply With Quote
NEVER MENTION DOLLIES!!!
There are hundreds of people towing cars/buggies/4x4's all over the country every weekend and, unless the towed vehicle is road legal, they are breaking the law.
Chances are that most plod don't know the regs or can't be bothered to find out because I have one that I use often and i have never been stopped. Unlike several peoples who got stopped leaving an off-road event up the road from me in a 'crack down'. About a dozen people were reported and charged.
You can try all the excuses you want but it helps to have a good convincing story ready if you do get pulled in the hopes that you can out shull bit the plod!! And have all the correct lights working and showing the tow vehicles (BS approved) number plate
http://www.ppcmag.co.uk
jonbeedle
posted on 24/11/05 at 06:09 AM Reply With Quote
AW Bugger!
NS Dev
posted on 24/11/05 at 09:02 AM Reply With Quote
It is actually quite complex, the law surrounding towing dollies, but owelly's description is not too wide of the mark in reality!
posted on 24/11/05 at 09:12 AM Reply With Quote
I think it comes down to - any vehicle with wheels on the public highway must be taxed, insured and road-legal. Even if it's only the back wheels!
rgds,
posted on 24/11/05 at 10:06 AM Reply With Quote
yep, that is how I understand it. It doesn;t need MOT if you have prearranged to take it for one.
Wait until we get some snow, then fix skis under the rear tyres so the wheels are no longer in contact with the road I wonder if that will hold up in court?
NS Dev
posted on 24/11/05 at 10:24 AM Reply With Quote
I'm not sure on the law actually, mark allanson knows a bit about this one, but I am not entirely sure that the car being towed has to be road legal in terms of tax and insurance etc as it is really a trailer at that point.
I know that recovery companies have various allowances within the law (for example a "recovery vehicle" does not have to be MOT'd technically.
I think "normal" people like you or I are best to assume that a towing dolly is not a good idea to use on a regualr basis, but probably worth the risk if it is only ever going to be an occasional thing.
Bob C
posted on 24/11/05 at 10:33 AM Reply With Quote
RE: towing dollies - towing in general: I recall being towed in my mazda (which had a BW T5 gearbox) and the gearbox quickly began to make grumbling noises. I worked out this was due to when being towed in neutral, the gearbox output shaft rotates but nothing else does, so no oil is being supplied to all the bearings on the mainshaft. And sure enough, press the clutch & stick it in 4th for a couple of seconds to spin the cogs and the noise goes away for the subsequent 5 minutes.
Point is, you're not necessarily doing the gearbox any favours if you tow a car in neutral for a long way with the driving wheels turning. Just a thought.
Bob
rayward
posted on 24/11/05 at 11:25 AM Reply With Quote
a towing dolly is only legal for recovery, and up to a max speed of 40mph on motorways and dual carriageways, and 20mph everywhere else(Road Traffic Regulations Act 1984 (Schedule 6).
hope this clears things up
Ray
zetec
posted on 24/11/05 at 04:23 PM Reply With Quote
You are OK as long as the dolly and towed vehicle have a combined weight of no more than 750KG. The problem is that over this weight all wheels of the towed rig must have either an automatic over-run or coupled brake system. As the dragged wheels of your car have neither, and I suspect the whole lot is more than 750KG then it's a no no...I was going to do the same!
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
jonbeedle
posted on 24/11/05 at 07:39 PM Reply With Quote
Aw bugger again!
owelly
posted on 26/11/05 at 09:02 PM Reply With Quote
Are we talking 'Dolly' as in the thing that lifts the wheels in a spectacle frame or an A-frame?
The dolly that lifts the wheels are the ones for 'recovery only' and are subject to a host of regs that make them impractical for general towing jobs (distance/speed limits etc)
I group dollies and A-frames in the same basket and so do the law when it comes to paperwork!! The towed (and tow) vehicle/driver needs to have valid insurance cover. Nearly all insurance policies state that the vehicle has to comply with the Road Traffic Act(s) which comes back to having MoT and VED (unless travelling to/from a pre-booked MoT)
