Agriv8
posted on 5/12/05 at 12:54 PM |
V8 emissions
Here is one I have been pondering about for a while but as I am getting to the piont where I need to get the emmisions under control. I though I would
pose the question.
I have an exhaust system for each bank of the V8 i.e. 1 each side of the vehicle. I am on a pre 95 engine with proof of age.
I assume that the levels I am allowed are the Total of each side. This total has to be less than the amount allowed for a pre 95 engine?
Anybody got any thoughts on this ?
Agriv8
froggy
posted on 5/12/05 at 01:08 PM |
carb or injection? flapper or hot wire?
Agriv8
posted on 5/12/05 at 01:14 PM |
froggy Hotwire 3.5 rebuilt with lumppy typhoon can.
Regards
froggy
posted on 5/12/05 at 01:37 PM |
i would imagine that one bank will be tested an adjustable fuel reg will help if its still running the factory regulator, the rover likes about 3.5%
at idle ,by the way what rad are you using? ive found if you can keep the water around 80 degrees they run really well and recover well from a good
boning but if it runs closer to 90 they do start to smell hot if you know what imean
Simon
posted on 5/12/05 at 09:58 PM |
Had my SVA test lasy Monday (which I failed - see thread elsewhere).
I did pass emissions (Rover V8 btw), only tested one side and only at tickover.
Engine was built in Dec 1979.
Simon
Agriv8
posted on 5/12/05 at 11:25 PM |
Thanks simon / Froggy.
Froggy using a pace 4 core ali rad that should be up to the job. fitting an oil cooler later this year ( certainly before summer ! ) hope i
Adj fuel regulator fitted.
Regarding the fueling using 14cux brain - green tune resitor and therfor no Lambda Sensors.
It smells a little rich but needs a run or two and then hook her up to the Analiser.
Many thanks for both your help Simon good look for the retest
froggy
posted on 6/12/05 at 11:11 AM |
i used to have a hillman avenger with a vittesse engine in and that used a 4core rad but it had to fit between the chassis rails so it wont be much
bigger than what your using it couldnt cope to start with but in the end it had a 75 degree stat and the 16" fan which was shrouded to get the
best from it came on at 75c and it would sit in traffic without bother. if you havent got it allready get the new v8 bible by des hammil its a
speedpro title got some good info and stuff from j.e. engineering and wildcat.
Agriv8
posted on 6/12/05 at 01:27 PM |
Thanks got a 1400 cfm fan behind rad so will hope its good enough but like the idea of fitting the 75 deg stat.
Regards
Iain
Guinness
posted on 6/12/05 at 08:53 PM |
Iain
Despite Simon having direct and recent SVA experience to the contrary, the draft version of the SVA Manual suggests that Mr SVA should have sampled
from both systems?
"7. Total gas emitted
The limits prescribed relate to the total exhaust gas being emitted by the vehicle. If a vehicle has a dual exhaust system, then the emissions from
the tailpipes should be averaged. This is done by adding together the readings and dividing by two, e.g.
1st pipe emits 6% CO, 400ppm HC
2nd pipe emits 4% CO, 500ppm HC
Average CO reading is 6 + 4 = 5%
2
Average HC reading is 400 + 500 = 450 ppm"
HTH
Mike
Agriv8
posted on 6/12/05 at 10:19 PM |
Thanks Guiness,
thats kinda what i thought so will aim for that moved under its own steam for first time yard forward and then back again thien sprung a huge water
leak of one of the hoses so after taking of a little skin on the old knuckles sorted that ant did a presure test all seems ok ready for run up and
down the drive tomorow.
what the engine really needs is a good thrashing as moisture build in rocker covers.
Thanks for the info
Regards
Iain
Simon
posted on 7/12/05 at 07:58 PM |
Mike,
You're absolutely right. He should've checked both side.
Bear in mind my noise test went something like:
"You're allowed 101db and that makes my ears hurt. This doesn't, so I ain't doing it!"
Fine by me I said
Simon
