joolsmi16
| posted on 16/12/05 at 02:52 PM |
Hydraulic clamps
Hi, would I be okay to use a hydraulic clamp to secure a brake banjo union??
The clamp is welded to the chassis and clamps the banjo union in between two half circules then you secure all of that two two M6 bolts?
Or I could put a thread on the banjo union its 13.7mm and secure the same as the front flexi, if anyone knows were I could source a die?
Thanks all
| posted on 16/12/05 at 05:22 PM |
Haven't a clue what you mean but almost certainly the SVA man wouldn't like either way.
joolsmi16
| posted on 16/12/05 at 06:56 PM |
Brake union clamp
Hi I've being trying to post a pic but failing error of can't find server keeps come up.
The clamp I am talking about in on this link:http://www.youngssurplus.com/Dscf5340.jpg.
Hope to use this more Mr SVA.
Jools
silex
| posted on 16/12/05 at 09:02 PM |
Yes you could use a Stauff style clamp around the furrel of the fitting, but generally those clamps are used to support the tube or hose along its
length, not generally the ends. If you needed to support the end fitting so securely you would probably be better off fitting it to a bulkhead union.
The bulkhead union can be fitted into a small piece of angle iron (or similar) which is welded onto the chassis.
Also, are you sure you are using a banjo union. A banjo bolt normally secures this type of fitting (the fluid runs through the bolt) so you would not
really need any additional support.
Do you have a pic of the hose / tube fitting ?
Murphy's 2 laws
1. If it can go wrong it will
2. In case of emergency - refer to rule 1.
joolsmi16
| posted on 16/12/05 at 10:48 PM |
clamps
I am failing to post any pics at the moment?? got the pic from the net.
I have a 3/16 brake pipe into a male union which inturn threads into a female/female union and then a banjo bolt into that.
A flexi runs from the banjo bolt and I would like to clamp the female/female union with the clamp in pic if its ok for sva.
Hope that makes sense.
silex
| posted on 17/12/05 at 05:17 AM |
I have never tried to SVA that situation, but my personal feeling would be no.
That type of clamp has only limited capability to stop rotation. If you use that clamp on the front wheels for example and the flexi runs out to the
hub, the steering and suspension movement applies a torque to the union. Even if the clamp is initially a good fit its grip will soon start to slip,
this will then allow the torsional effect to transfer through into the metal tubing, which will in time (probably quite quickly) fracture and fail.
Then you have lost your brakes .
Murphy's 2 laws
iank
| posted on 17/12/05 at 10:01 AM |
Semi OT
Posting a picture.
If it works in your web browser using a http:// address (rather than file://)
use something like
[img]http://foo.bar.baz/bigwobblyones.jpg[/img] in your post.
If it's on your disk you will need to upload it to your photo archive (size limitation and unique name required) and use the address:
[img][/img]
joolsmi16
| posted on 17/12/05 at 10:08 AM |
pipe clamps
Any other ideas how to hold the female/ female union then?? its 13.7mm in diameter looking to put a thread on it and mount through a bracket and
secure with nuts, same as front.
Anyone know what die with turn a 13.7mm.
| posted on 17/12/05 at 10:40 AM |
To attach an image to a post it has to be on your own computer not somewhere on the web. Download the image to your desktop then attach your
desktop copy to the post.
joolsmi16
| posted on 17/12/05 at 10:53 AM |
If the pics below I upload to my yahoo forum, failed to upload on this forum and then downloaded to desktop and how to here!!??
