Author: Subject: brake pipes need separate clips?
posted on 21/12/05 at 11:04 AM Reply With Quote
Did I dream this up as I cannot find a reference to it. I am sure I have read somewhere that brake lines need a separate clip when held in place i.e. one clip cannot hold 2 brake lines side by side.
SVA makes no mention other than being secure.
So a dream or a fact?
smart51
posted on 21/12/05 at 11:11 AM Reply With Quote
I have held 2 brake pipes with 1 P clip in places. SVA man didn't complain. That said, I only did it with 1 or maybe 2 clips.
ReMan
posted on 21/12/05 at 12:16 PM Reply With Quote
If you use a double pipe clip then they are made for the job.
If you put the two metal pipes in the same clip, touching, then thats probably not so good and there is a potential for them to chafe together and fail....
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
zxrlocost
posted on 21/12/05 at 12:49 PM Reply With Quote
jrt automotive
his names terry
01494792211
tell him chris sent you and your building a kit car'
tell him you need some of the triple brake pipe clips that push
they only need one hole drilling and hold three pipes not that you need three
but they still look ace
DarrenW
posted on 21/12/05 at 01:17 PM Reply With Quote
Play safe - dont let them touch anything (inc chassis).
You might get away with it at some tests, i know i wouldnt have.
