| posted on 9/1/06 at 12:03 PM |
angled fog/reverse lamps
those with good memories my remember my post aboutthe angle of rear fog/reverse lamps (off Land Rover) and possiblilty of modifyingthe plastic
case.
In short, not possible due to dept of the reflector.
I think I know the aswer to this but I guess fitting a pair of aluminium brackets like these
is an SVA no-no due to sharp corners perhaps?
andyd
| posted on 9/1/06 at 12:49 PM |
If you can radius them to 2.5mm or more then they'd be ok. Possibly using some edging strip of some sort?
DarrenW
| posted on 9/1/06 at 02:18 PM |
I bought those cheap square lights (fog and reverse), mounted them on long threaded bar to get height correct and simply bolted some flat plate from
bottom of chassis that extends past back panel. All radiussed and then covered in some large split hosepipe type tube. No brackets and holes therefore
required in back panel in case i get some better lights in the future.
k33ts
| posted on 9/1/06 at 05:15 PM |
why dont you make some out of fibre glass as i see your gona be mixing some up anyway
