RichieC
| posted on 3/2/06 at 08:46 PM |
Rear Reflectors
Hi all,
Had a look through the SVA manual and I cant see anything relating specifically to this but someone may be able to shed some light on it (no pun
intended)
Is there a minimum "reflectivity" for rear mounted reflectors? Halfords have some self adhesive reflectors in for about 2 quid a pack and
would be easily removed, but theyre really just reflective tape and Im not sure if mr SVA would approve.
Alternatively, is there a known source for fit and forget reflectors as I dont want to be ar5ing about with radiussing them etc etc.
Thanks in advance
Richie
[Edited on 30/12/08 by RichieC]
smart51
| posted on 3/2/06 at 09:04 PM |
Reflectors must be E marked and either radiused at 2.5mm or less than 4[I think] mm thick.
My SVA inspector failed mine because they were 5mm thick and unradiused. He seemed a little emabarased that he had to fail them, saying that above
"this" line you could have razor blades fitted and it would pass.
He didn't check reflectivity at all.
RichieC
| posted on 3/2/06 at 09:05 PM |
Ah yeh of course, I overlooked the E marking.
Above what line was he talking about?
Rgds
Rich
RazMan
| posted on 3/2/06 at 11:03 PM |
I just had a rummage through the SVA manual and all I can find about rear reflectors is that there can be any number as long as they are red and not
triangular.
Have I missed something?
Raz
RichieC
| posted on 7/2/06 at 05:01 PM |
Just had a look myself and I cant see anything about e marks either.
Do you have a page number or anything Smart51?
Thanks and Rgds
Rich
smart51
| posted on 7/2/06 at 06:38 PM |
Ooo. Now you've got me. I just assumed that they had to be E marked. Mine are. Is it not on the page with the rear lights? They do have to
comply with exterior projection radiusing rules though.
RichieC
| posted on 7/2/06 at 06:47 PM |
No, theres nothing on that page, just their placement and that they cant be triangular.
If they stick out >5mm, yep theyll be subject to the external projection radius check.
Rgds
Rich
RazMan
| posted on 7/2/06 at 09:22 PM |
There's not even a regulation about their size either, so they could be tiny as long as they are 'clearly visible'
Raz
