rickys2000
posted on 12/2/06 at 08:02 PM |
SVA and Steering
Does anyone have a contact name for someone at the SVA office in Leighton Buzzard............I need to find out if I can use a Honda column and switch
gear mated to the Sierra column triangular end.
thanks
Ricky
mookaloid
posted on 12/2/06 at 08:15 PM |
Can't help with your question, but I would suggest that you would need to satisfy them that your jointing method is sound, also the triangular
bit is the collapsible bit for the sierra column so if you weld or bolt to it you will probably no longer have a collapsible column which could be an
issue.
Apart from being an issue, would you want to use a non collapsible column?
HTH
Mark
Howlor
posted on 12/2/06 at 08:16 PM |
As long as the Honda column has a collapsable section or retains the sierra sliding triangular mount then this combination should not be a problem for
SVA. They only look for key features of design rather than where they came from.
Viper
posted on 12/2/06 at 08:20 PM |
thanks
Ricky
I was going to have my sva done at Leighton but was warned off the place as the inspectors were born out of wedlock, apparently they are not very
helpfull.....
but this isnt a first hand experiance...
rickys2000
posted on 12/2/06 at 08:24 PM |
The idea is to keep the Honda collapsible section and weld the triangular end to that just beyond where it passes through the bulkhead.
Hmmm, if LB are not helpful are there any other friendly inspectors I could talk to.
Ricky
Viper
posted on 12/2/06 at 08:50 PM |
I have heard Derby are nice people...
if you go on the gov sight you can pull up a list of all the sva centers, i think there are contact numbers as well, but be warned if they are testing
they arent going to want to be pulled away to chat on the phone.
RichardK
posted on 12/2/06 at 09:32 PM |
List of centers with contact details
here
Regards
Rich
[Edited on 12/2/06 by RichardK]
