joolsmi16
posted on 11/3/06 at 05:15 PM |
rront fuel tank
Hi all, having read through a pdf SVA file I can't find any info on fuel tanks and positioning of.
I would like to use a bikes fuel tank mounted in the front and wondering if there will be any SVA issues.
Also are rosejoints on rear IRS handed L&R/H?
posted on 11/3/06 at 06:17 PM |
If it's well secured and doesn't leak there should be no problem or bikes would be baneed from the road. On some of them you sit on top of
the tank and the exhaust is right below them. You could always ring the SVA centre and ask them, they were always helpful when I consulted and can
usually clear things up.
emsfactory
posted on 11/3/06 at 07:59 PM |
Did Dax not do one with the tank in the scuttle? I cant see a problem with it provided it's safe.
I also called my SVA guy a number of time on different points. Always happy to help.
Must be a bit different to dealing with disgruntled truckers.
