Author: Subject: Using the same rivet for 2 P clips
JoaoCaldeira
posted on 25/3/06 at 08:22 AM Reply With Quote
Hi all.
Is there anything against using the same hole/rivet to hold 2 P clips (for example one for loom and one for brake line)?
Near the diff I would save a few chassis holes...
Thanks in advance,
Joao Caldeira
westf27
posted on 25/3/06 at 08:48 AM Reply With Quote
would think that is ok but keep the p clips opposed to each other for clearance and make sure they insulated clips to protect loom and line from abrasion.Also clip every 300mm
[Edited on 25/3/06 by westf27]
MikeR
posted on 25/3/06 at 09:13 AM Reply With Quote
only issue is the clamping range of the rivet. if it can cope with the thickness, then you should be fine.
piddy
posted on 25/3/06 at 09:49 AM Reply With Quote
Hi.
I've done this in a few places, however I have drilled and tapped a hole and then used a small (4mm) mushroom head bolt to attach them.
Krismc
posted on 25/3/06 at 09:59 AM Reply With Quote
sorry to hyjack ya post but........
I was under the impression it was max 6inches between clips for brakes,fuel and wiring, so mine are all just under will i be ok?? and near the ends where i have single cables what do i do?
MikeR
posted on 25/3/06 at 12:41 PM Reply With Quote
I haven't checked the sva manual in a while but i think it was 30cm and must be secure as the criteria. 15cm will be plenty, make the examiner happy and means he'll be more likely to think "good build" as opposed to "this is worrying, lets look at everything further".
Krismc
posted on 25/3/06 at 05:22 PM Reply With Quote
yea i suppose ya right!
whats the regular things people fail on
NS Dev
posted on 26/3/06 at 10:46 AM Reply With Quote
yep, its 300mm, so you'll be more than ok at 6 inches! (said the actress to the bishop)
on the first point, yep 1 rivet for 2 p clips in opposing fashion is fine and also looks very neat and tidy!
