Author: Subject: brake liune passing trough a bulkhead
posted on 31/3/06 at 09:43 AM Reply With Quote
nowt to do with me but question has arisen about whatto do with a brake linbe that passes trhough a metal bulkhead.
Is using a rubber grommet ok (does SVA say anything about this?)? And how esle to do this? (i.e., is a bulkhead connector the only acceptable way and should adding another join be a concern).
posted on 31/3/06 at 10:28 AM Reply With Quote
Rubber grommet should be o.k. That's how mine are done on my van through the front inner wing.
Nick Skidmore
posted on 31/3/06 at 10:29 AM Reply With Quote
Don't know about the legalities but I've done both and think that the bulkhead fitting is a better 'engineering' solution
DarrenW
posted on 31/3/06 at 01:38 PM Reply With Quote
Best bet is to see how the OEMs do it and try and do the same yourself.
