Markp
posted on 24/3/03 at 08:40 PM |
A few questions
Hi all!
I've been building a locost for about three and a half years and it;s almost ready for the SVA. I,ve been reading a lot in to it and have a few
questions I can't find the answers to.
* Are you allowed to have a K&N poking out the top of the bonnet?
* Do you need to have a rollbar for the SVA?
* Do you need a cover for the rear luggage space thing?
* Do they work out all the weights, gravity etc..?
* Do you only need a heat sheild on the silencer part of the exhaust or the whole down pipe?
That's it for now, Any help would be great, I'm sure i'll think of plenty more.
Mark
david walker
posted on 24/3/03 at 10:12 PM |
--- YES
--- NO
--- NO (but easier to protect sharp edges if you do)
--- YES
--- You don't need one on pipe, you may not actually need one on silencer (?) but when you burn your leg you'll fit one. Watch sharp
edges.
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
Mark H
posted on 25/3/03 at 08:58 AM |
Some food for thought, but could well be cobblers:
K&N: I thought it was a fail to have it sticking out "naked". I could well be wrong - either way, any sharp edges will need
covering.
Cover: If you do not have a locking petrol cap on your tank, you will need a locking cover of some sort. If it has a lock, the cover can just be a
stretched piece of vinyl (and then all the sharp bits inside is no longer an issue).
Weight: You need to put some axle weights on the SVA form. There is some estimates elsewhere on this site!
Hope this helps!!
Mark
Mark Harrison and
Q986 KCP back from the dead...
david walker
posted on 25/3/03 at 08:56 PM |
Sorry if I have misled, there must have been SVA changes in the last year.
K&N Filters used to compliant (radii & the like). Mine passed OK.
My car also passed with a non locking petrol cap within the boot compartment, with the boot only covered with vinyl cover. I think if cap is exposed
it has to be locking for MOT.
gjn200
posted on 25/3/03 at 11:15 PM |
I think we (ok, I) need some clarification on the air filter out of the bonnet bit, mainly because it could save us (ok, I) initially £500 on a pair
of webbers. Please anyone know?
[Edited on 25/3/03 by gjn200]
<- Me!
theconrodkid
posted on 26/3/03 at 05:14 PM |
depends on the "hardness" anything hard has to have radiused edges,mine is soft foam(air filter that is)and is ok,anything metal showing
may cause a prob.
who cares who wins
pass the pork pies
MikeyG
posted on 13/4/03 at 08:25 PM |
Regarding vehichle weights - mine failed on this too. The inspector kindly informed my that you should just put in
Front 400Kg
Rear 500Kg
total 900Kg
This should be sufficient for most of our little babies......if i fail again i'll give you all an update.
david walker
posted on 14/4/03 at 09:56 PM |
Thats one heavy Locost! Hasn't your car got a K Series engine?
Trouble with putting excessive weight down on the form is that your braking efficiency requirements are checked (front, back and both) according to
axle weights. You need to be on the heavy side but I would have thought that 900kg was too high. Even if accepted you may have problems achieving
brake efficiency AND balance.
When I went through my test and (as required) having checked axle weights etc beforehand and filled out on the form, my SVA inspector said that they
were "close enough" for him to accept but he would "modify" them a little. I got the impression that unless I had made a good
effort he would have failed me.
The procedure for calculating the weights and filling the form in is all explained in the SVA manual.
Viper
posted on 15/4/03 at 06:51 PM |
the Vin plate supplied to me by Tiger has the design weights on ot and they are
front 450kg
rear 500kg
all in 950kg
make of that what you will, i am not saying its right but tiger haveput one of these through the test..i think..
david walker
posted on 15/4/03 at 06:58 PM |
Viper, isn't that with a full Sierra brake set up? Is it using a servo and isn't it with a Pinto?
If so the heavier weights / different brake arrangements are probably OK, I think the Avon is different to a std book type Locost.
Viper
posted on 15/4/03 at 07:04 PM |
The Avon uses a Sierra master cyl, no servo, sierra rear drums and cortina discs and callipers up front....
and a pinto
[Edited on 15/4/2003 by Viper]
