nitram38
posted on 11/4/06 at 11:00 PM |
Can you tell what it is yet?
stevec
posted on 11/4/06 at 11:03 PM |
Gear Knob.
welderman
posted on 11/4/06 at 11:07 PM |
FIA cut off switch, one pence coin and a black something
So sva freindly edges
[Edited on 11/4/06 by welderman]
Thank's, Joe
I don't stalk people
nitram38
posted on 11/4/06 at 11:08 PM |
quote: Originally posted by stevec
Gear Knob.
No dead cold
nitram38
posted on 11/4/06 at 11:11 PM |
Bang on!
(the black something is the immobiliser key fob)
nitram38
posted on 11/4/06 at 11:12 PM |
Bang on!
I used a clear resin kit off ebay. Normally used for paperweights.
Let the sva man fail an fia switch now!
The 1p coin is magnetic, so I can even hang the key up!
[Edited on 11/4/2006 by nitram38]
welderman
posted on 11/4/06 at 11:26 PM |
Thank's, Joe
ned
posted on 12/4/06 at 06:23 AM |
does that keyfob have batteries that might need changing?!
Ned.
beware, I've got yellow skin
k33ts
posted on 12/4/06 at 07:09 AM |
cool, good thinking
tukcustoms.com
nitram38
posted on 12/4/06 at 08:20 AM |
Ned.
No it is a transponder type. There is a chip inside and a coil around the fia switch (under the panel). When the chip is near the coil, the coil
produces a magnetic/radio signal that energises the chip. The chip then gives off the code to disable the thatcham immobiliser.
That means that some theif with just an fia battery key, cannot nick my car
trifield
posted on 12/4/06 at 12:37 PM |
very neat
DIY Si
posted on 12/4/06 at 04:12 PM |
Much better than the half tennis ball idea I suggested a while back. Good plan that, Batman!
