Author: Subject: Dash for SVA
joolsmi16
posted on 26/4/06 at 03:43 PM Reply With Quote
Dash for SVA
Hi all, is there a list on the forum to highlight what is required on the dash for SVA.
I am using blackbird clocks and switch gear, so I gather that I will need in addition:
Side light switch
Handbrake warning
Brake fluid warning
Hazards
Fog
Also because of space I hope to have a centre section below about 6 inch from the centre of the dash what's the radius rule for SVA hoping to make out of 22mm round tube to house the above switches.
zxrlocost
posted on 26/4/06 at 03:48 PM Reply With Quote
just make sure everything is within the 127mm of the sierra steering wheel and you can make it out of what you want
some nice ally tube ie chromed
PS I did this with the r1 switch gear just to drive my car as I have savage switches for when I have time to wire up
but IMHO bike switch gear looks shite in a car
at first I thought it would look ok
PS you are correct about switches
but hasnt the bike got sidelights that can be turned on and off?
chris
zxrlocost
posted on 26/4/06 at 03:50 PM Reply With Quote
the brake and handbrake warning light are the same thing the switch is a push button on top of the master cylinder and obviously the handbrake when applied
I would get a fan switch as these BECs get hot
posted on 26/4/06 at 03:52 PM Reply With Quote
I beg to differ...
each to there own I guess....
Re: fans, could use a toggle switch hidden away as only really necessary on track or when tonking it... or are they the same?
[Edited on 26-4-06 by Hellfire]
tks
posted on 26/4/06 at 04:12 PM Reply With Quote
127mm
can you explain that for me please?
need the buttons be there or the complete dash incl lcd´s etc??
or only the warning / attention lights??
Tks
jos
posted on 26/4/06 at 04:27 PM Reply With Quote
The exemption zone (where you can put pretty much whatever you like) is 127mm bigger than you steering wheel which means that it doesnt matter whether your switches gauges warning lights etc meet minimum radius requirements as withing the exemption zone there is no minimum radius
[Edited on 26/4/06 by jos]
zxrlocost
posted on 26/4/06 at 05:12 PM Reply With Quote
hellfire when i say the switch gear looks no good I mean the actual switches My r1 clock looks ace!!!! in its place
tks
posted on 26/4/06 at 07:44 PM Reply With Quote
sow
it says
put all your buttons and lights and the complete dash
out of that zone..??
What are the rulez about visuality?? of the speed/revs/warningslights??
Tks
zxrlocost
posted on 26/4/06 at 08:36 PM Reply With Quote
take the left hand side of the steering wheel and measure 127mm
put all your gauges switches etc inside this area
things can still be fitted anywhere else on the dash but they will be checked for killer edges
chockymonster
posted on 26/4/06 at 11:43 PM Reply With Quote
Didn't you mean to say take the left hand side of the biggest possible bus sized steering wheel you could possibly fit?
tks
posted on 27/4/06 at 05:41 AM Reply With Quote
to clearyfy
But when i look at hellfires picture it looks like he didn´t mounted it within the 127mm limit..right??
Tks
zxrlocost
posted on 27/4/06 at 08:56 AM Reply With Quote
thats right but he will have been checked for radius most likely or he will have covered the dash with vinly to make the dials sit in more
ill put some pics of my car up later and youll see what I mean
ta chris
tks
posted on 27/4/06 at 11:26 AM Reply With Quote
i was planning to use savage switches
Are they radius conform the SVA??
I also wanted to build a overlay out of 2mm stainless..
Sow in the sheet there will be 2mm of sharp edge will that be a problem?
How could i manage this trick to be SVA compliant with out using venyl and stuff
would a champfer be enough??
Tks
