Author: Subject: sva noise level
westf27
posted on 7/5/06 at 09:39 PM Reply With Quote
sva noise level
sva retest 8.00am tomoz.Failed on 103db at 4250 rpm 2l pinto.Can we have a quick show of hands.....need some sleep,is that rpm 4250 too high my reference says 3500rpm
smart51
posted on 7/5/06 at 09:44 PM Reply With Quote
I seem to recall that it is 3/4 of the speed at which maximum power occurs.
4250 is 3/4 of 5666 RPM
wilkingj
Buy a Rev limiter
PS.. dont know the answer, but will find out on Tuesday! (SVA for me)
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 7/5/06 at 09:48 PM Reply With Quote
IIRC, you have to state on your SVA application form, the RPM at which max power occurs. It is this figure which then determines the noise test at 3/4 of the declared RPM.
Does that make sense?
Phil
westf27
posted on 7/5/06 at 09:55 PM Reply With Quote
Thanks guys....goodnight
nitram38
posted on 7/5/06 at 10:01 PM Reply With Quote
My engine revs to about 6000 (1.4 k-series) and Peak power is 4500.
So they should test at 3375 max?
russbost
posted on 7/5/06 at 10:04 PM Reply With Quote
Depends what you declared on the SVA form Martin - should have read my article more carefully!!!
posted on 7/5/06 at 10:12 PM Reply With Quote
westf27, good luck with the re-test tomorrow.
Phil
And from me!
[Edited on 8-5-06 by Hellfire]
westf27
posted on 7/5/06 at 10:25 PM Reply With Quote
thanks phil sorted all the fiddlys only noise level iffy.fitted a db killer hope it works.might ask him to qualify his rpm value if it fails as it appears my peak power rpm is 5500....3/4 of which is 4125
nitram38
posted on 7/5/06 at 11:09 PM Reply With Quote
I put 4500 on the form!
Never mind, my car is quiet against 2 kwackers!
DarrenW
posted on 8/5/06 at 09:07 AM Reply With Quote
My tester ignored what i put on the form. Tested at 3,900 rpm but i was well within (approx 93dB).
Good luck - sorry this reply was too late to help you.
irvined
posted on 8/5/06 at 01:03 PM Reply With Quote
I put down 5500 on my form, guy let me sneakily change it down to 5000, it wouldnt have mattered in my case anyway, but i think if you've got a good argument you can use a lower value, mine was that it simply doesnt rev that high
P.S 98db on one of those shiny cans i got last year.
http://irvined.blogspot.com
