jonbeedle
| posted on 8/5/06 at 04:27 PM |
SVA applied for...Gulp!
Hi fellow Petrol heads,
I haven't been here for a while. I'm afraid the car has had to take a bit of a back seat.
I've been on the road with the band. Been to Poland to record with one of their finest orchestras, more about that another time though.
Any way upon my return I've taken the plunge and applied for the SVA. I Haven't got a date yet.
Here are the obligatory pre SVA pics for your perusal. If you see anything obvious then do let me know. As you will see the screens have fallen off in
the later pictures!
"Everyone is entitled to an opinion however stupid!"
jonbeedle
| posted on 8/5/06 at 04:29 PM |
pic no 2
jonbeedle
3
jonbeedle
| posted on 8/5/06 at 04:30 PM |
4
jonbeedle
5
theconrodkid
| posted on 8/5/06 at 04:32 PM |
looks good,did this orchestra include someone who looks like the hairy bloke from simply red,plays a flute type of instrument?
who cares who wins
pass the pork pies
jonbeedle
| posted on 8/5/06 at 04:33 PM |
This is steam pipe lagging!
jonbeedle
7
jonbeedle
| posted on 8/5/06 at 04:34 PM |
8
jonbeedle
9
jonbeedle
| posted on 8/5/06 at 04:35 PM |
10
At Eye Airfield Suffolk
muzchap
| posted on 8/5/06 at 04:47 PM |
Jon is that a type 9 box?
Be interested in that Gear Gate design
Looks ace!
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
andyharding
| posted on 8/5/06 at 04:51 PM |
I'm sure the pipe lagging will fail. It needs to be covered in cloth/leather/vinyl and well attached to be considered permentent.
I "tried it on" on my first SVA. They told me right away I'd fail on that and I saw their point as by the end of the test the
lagging was already showing wear from all the getting in and out.
jonbeedle
| posted on 8/5/06 at 04:53 PM |
Looks ace!
Thanks for the compliment. No it's a Mk2 Escort 4 speed box.
Jon
wilkingj
That looks distinctly like an EX - BT Plant Trailer. If So... I bet you are probably overweight for the towng cars limit.
Those trailers weigh close to a ton, + 1/2 ton for the car. Check the total weight as you could be nicked for it. ie what's the Max Braked
trailer towing limit in your hand book?, and how much does the trailer and locost weigh?.
If you passed your car driving test after January 1997, you may now need to pass a separate test (licence category B + E) to tow a trailer or caravan
weighing over 750kg M.A.M. (Maximum Authorised Mass).
http://www.learners.co.uk/towing/towing-txt0.htm
Just my 2d's worth.
Car looks good. Shouldnt take long to get a a date for the SVA.
Good Luck with the SVA.
Best Regards
Geoff
http://www.v8viento.co.uk
jonbeedle
| posted on 8/5/06 at 04:56 PM |
It's proper vinyl type steam pipe lagging on the exhaust and the pipe lagging on the cockpit sides is glued on and covered in vinyl. The pipe
lagging on the bottom of the dash is glued on and is a type of foam rubber which is not covered.
Jon
jonbeedle
| posted on 8/5/06 at 04:58 PM |
Just my 2d's worth.
No idea about the trailer, I just borrowed it once. I passed my test in 1979!
Thanks for the compliments about the car.
Jon
splitrivet
| posted on 8/5/06 at 05:14 PM |
Cant see any rear reflectors Jon or is that em above the reversing Lights.
Bob
mangogrooveworkshop
| posted on 8/5/06 at 05:29 PM |
Nice seats
[Edited on 8-5-06 by mangogrooveworkshop]
jonbeedle
| posted on 8/5/06 at 05:32 PM |
quote: Originally posted by mangogrooveworkshop
Nice seats
Yep Thanks for those!
jonbeedle
Bob
Yep that's them!
pajsh
| posted on 8/5/06 at 08:05 PM |
I agreee with the pipe lagging comment. I was told I could not use it as it was not what a mainstream manufacturer would use.
Edges of top seatbelt clips look contactable to me and probably need rubber edging if less than 2.5mm rad.
Are front indicators far enough out. Look more than 400 from the outside if the tyres are 195 ish.
All I could see though. Front suspension looks well covered.
[Edited on 8/5/06 by pajsh]
I used to be apathetic but now I just don't care.
omega 24 v6
| posted on 8/5/06 at 08:18 PM |
Nice work. The top hose from the thermostat to the radiator looks like it could foul on the exhaust and the fan belt. The brake hose to the front
caliper looks a bit floppy hangy and might need tied up. Other than that it looks good.
Dave J
| posted on 9/5/06 at 12:53 PM |
Nice work, the car looks great.
Can't quite tell if your seat harness triangular fixing brackets are either radiused or have rubber trim round.
Mine were straight edged so I had to glue rubber trim to effect the appropriate radius.
All the best with the SVA
Dave.
