Author: Subject: current year registration
doughie
posted on 13/5/06 at 07:01 AM Reply With Quote
hi
i am looking for advice about how to achieve a current year registration (i.e. '56' on a home built car
can anyone help...
iank
posted on 13/5/06 at 07:27 AM Reply With Quote
You need to build with all new parts (with receipts for proof)
One component (engine or gearbox usually) can be reconditioned to 'as new' condition.
http://www.dvla.gov.uk/vehicles/regrebil.htm
Confusing it's catagory C Kitcars.
I think the "Certificate of Newness" they rattle on about only applies to imported cars.
One downside of (apart from the cost) is you will get tested at MOT for the current emissions standards.
smart51
posted on 13/5/06 at 08:38 AM Reply With Quote
...or you can use a current plate donor.
doughie
posted on 13/5/06 at 11:13 AM Reply With Quote
lot of money for nowt i guess!!
07 seven would look cool though!!
posted on 15/5/06 at 09:48 AM Reply With Quote
mebbe so but you could get an older plate with zero-7 or oh-7 in the reg. for much less if you get an ager related reg.
I take it you can change the plate after wards if you have non-Q reg.?
iank
posted on 15/5/06 at 12:52 PM Reply With Quote
There is a consulting document on the dvla website which implies you can't/won't be able to transfer age related plates to/from kitcars.
http://www.dvla.gov.uk/public/consult/veh_inspec/vi_kitconvers.htm
Section 64.
Marcus
posted on 15/5/06 at 01:27 PM Reply With Quote
As I read the document, you can transfer a plate to a kit conversion, but the original plate issued after SVA, is non transferable. So if you've been issued with a nice plate at SVA and want to sell / transfer it, TOUGH!
Marcus
Marcus
Because kits are for girls!!
Schrodinger
posted on 15/5/06 at 02:26 PM Reply With Quote
If your one component that is reconditioned is the engine which happens to be pre Aug 97 then you will not have to meet current emission regs but the regs for that engine.
BKLOCO
posted on 15/5/06 at 04:36 PM Reply With Quote
Section 64.
The way I read this is that you would not be allowed to put a NEWER plate on an age related plate vehicle!!!
I think you can at the moment due to the FIRST registration date being the date you register it.
For example at the moment if you have an age related reg of say "F" yoy could puschase a cherrished plate of say "X" they are proposing that you should not be allowed to put a later than "F" plate on.
Schrodinger
posted on 16/5/06 at 11:30 AM Reply With Quote
It should be that if you were allocated an age related plate (in my case J reg) then that should be the newest reg you could put on it. However, I registered my Tiger Cat with a cherished number and have just put that number on retention as I am selling the Cat I have been given AY 51 NRV as the new registration (first reg Feb 2001)!!!
And I thought the DVLA knew what they were doing!!
[Edited on 16/5/06 by Schrodinger]
BKLOCO
posted on 16/5/06 at 12:01 PM Reply With Quote
That's exactly what I'm saying.
At the moment this is exactly how their stupid system works.
They are proposing that this changes so that you can only put an older plate than the age related that you were first issued with.
