Author: Subject: Size of Chassis number?
donut
posted on 16/5/06 at 01:06 PM Reply With Quote
How big (acording to the SVA manual) do the chassis number need to be. I need to stamp the number on my chassis but before i do i want to make sure i get it right.
Thanx
flak monkey
posted on 16/5/06 at 01:20 PM Reply With Quote
Not less than 4mm according to my SVA manual...
Section 22 of the manual, page 222.
Sera
http://www.motosera.com
posted on 16/5/06 at 01:38 PM Reply With Quote
^^^^^ exactly wit he said. Machine Mart sell 4 mm stamps.
... sight hijack, how permanently fix does the plate need to be - rivets or self tappers?
posted on 16/5/06 at 01:41 PM Reply With Quote
My main one is riveted, and glued with sikaflex!
Don't be surprised if your local DVLA man asks you to stamp the number somewhere else, as a backup (mine did - so I put it on the chassis member just behind the radiator).
bob
posted on 16/5/06 at 01:46 PM Reply With Quote
Mines riveted on drivers side under the bonnet,also engraved onto floor in front of drivers seat.
SVA was fine with the riveted version.
zxrlocost
posted on 16/5/06 at 01:47 PM Reply With Quote
mine was a simple engraved plate from the cobblers shop
and it can be pop riveted each side
DarrenW
posted on 16/5/06 at 01:49 PM Reply With Quote
How big does it have to be - 17 digits i think
Sorry, couldnt resist. i used 8mm i think. They dont measure it - just have to easily be able to see it.
donut
posted on 16/5/06 at 02:32 PM Reply With Quote
I think i'll call the SVA centre to see if i can put it on a plate.
Cheers peeps!!
ditchlewis
posted on 16/5/06 at 02:34 PM Reply With Quote
Mine is stamped on to the chassis in three different places.
ditch
posted on 16/5/06 at 02:36 PM Reply With Quote
5mm here.
I've stamped a few onto plates cut from 16g for myself and others then welded them onto the chassis. They have all been o.k. so far.
[Edited on 16/5/06 by Peteff]
BKLOCO
posted on 16/5/06 at 02:40 PM Reply With Quote
The SVA inspector told me it had to be "permanently" fixed.
It is up to the individual inspectors to deceide what "permanently" means.
Mine would NOT accept screwed or rivited. It had to be welded or stamped into chassis.
Luckily I had all 3
timf
posted on 16/5/06 at 02:52 PM Reply With Quote
similar
i took the top rad member (LC) to the cobblers and he engraved that, if they don't like my vin number then i'm stuck
A prisoner of war is a man who tries to kill you and fails, and then asks you not to kill him."
- Sir Winston S. Churchill, 1952
donut
posted on 16/5/06 at 03:04 PM Reply With Quote
I have just got off the phone to my SVA centre and the chap said that a riveted chassis plate would be fine
DarrenW
posted on 16/5/06 at 03:07 PM Reply With Quote
DVLA told me it had to be welded on.
Ive also put an engraved plate on scuttle panel and also wrote the chassis number all over the place elsewhere (some not visible until you take a bit off). Kind of microtagging but not so micro.
