Author: Subject: Dashboard lights
tks
posted on 24/5/06 at 01:08 PM Reply With Quote
Dashboard lights
Wich dshboard lights are SVA needed??
- Direction 2 or just 1??
- OIL??
- Neutral?? (or can it be display??)
- Alarm (the triangle??)
- battery??
- High Beam (sure of it)
- rear fog
anyone something to add?
only want to know wich ones are obligatory:
- High Beam
Tks
flak monkey
posted on 24/5/06 at 01:15 PM Reply With Quote
Only obligatory warning lights for SVA are:
Brake fluid level
Rear fog light 'tell tale'
Indicators
Hazard lights (can use the same as indicators)
Thats i as far as i can see
Sera
http://www.motosera.com
posted on 24/5/06 at 01:17 PM Reply With Quote
SVA require:
Either 1 or 2 direction indicator (1 light flashes if either indicator is working, or 1 for each side)
Hazard warning (the triangle)
High beam
Rear fog.
Everything else is optional, although I would suggest:
Oil pressure
Ignition (battery)
And, if you have a bike engine, neutral.
tks
posted on 24/5/06 at 01:22 PM Reply With Quote
colours
i'm sure the colours also have rules
i wanted to use
Blue for high beam
green for indicators
red for oil, hazard
Neutral will then be displayed on my screen
have bec sow battery would useless // no taking/source/connection point i guess..
sow i untherstand well, the fog light (tell tale) can also be in the button??
Regards,
Tks
[Edited on 24/5/06 by tks]
flak monkey
posted on 24/5/06 at 01:24 PM Reply With Quote
Manual says nothing about light colours. Why not download a copy and take a look? Its a nightmare to find anything specific! Most of what you want is in section 9 and 16
Only one that theres actually any specific regulations for is the low brake fluid light. The hazards warning light doesnt have to have the 2 triangles on, it can use the same telltales as the indicators.
Link
[Edited on 24/5/06 by flak monkey]
Sera
tks
posted on 24/5/06 at 01:26 PM Reply With Quote
OK
ok thanxs..
could find it anymore
and thought that it was a out of head question... (an easy one)
Thanxs
Tks
RazMan
posted on 24/5/06 at 02:36 PM Reply With Quote
You will also need a brake test switch wired to the fluid level warning circuit - I fitted a switch to the handbrake lever.
Raz
tks
posted on 24/5/06 at 03:27 PM Reply With Quote
mhh
sow in fact, the handbrake light isn´t obligatory??
thought it was the same on as the lfuid level..
Tks
flak monkey
posted on 24/5/06 at 03:28 PM Reply With Quote
The brake fluid level light is obligatory. Its usually tested by the handbrake in most production cars. The SVA requirement being that it must be able to be tested from the driving position. A push button on the dash is acceptable.
Sera
tks
posted on 24/5/06 at 06:26 PM Reply With Quote
Ok
any one good idea, how i can make the
symbols to be able to stick them near the led
Tks
ReMan
posted on 24/5/06 at 06:35 PM Reply With Quote
http://www.vehicle-wiring-products.co.uk/VWPweb2000/switch-3/switch-3.html
See symbol sheet........
tks
posted on 24/5/06 at 07:06 PM Reply With Quote
yeah
hop i can pay with paypall or are they on ebay to??
also the brake fluid symbol i need is the
combination of both because its also the parking one,
on my tintop its just the ! sow it should be good.
Also i'm not gona fit an extra hazard light.
I'm just gonna connect the Led in the button to one sidelight sow it will dance to with the rythem of it.
Also the button will be dimmed when contact is on sow not only when lights are on.
(like in my tintop)
Tks
John22000
posted on 24/5/06 at 11:30 PM Reply With Quote
As far as I know the handbrake / Brake fluid warning light HAS to have the correct symbol on it, any old red light will not be sufficient.
Regards,
John
stevebubs
posted on 25/5/06 at 12:35 AM Reply With Quote
The Bright 6 module has everything you'll need to run the car...
http://www.bright6.co.uk/
Any more is pure luxury
Stephen
(11 lights on my dash)
Viper
posted on 27/5/06 at 02:13 PM Reply With Quote
Stephen
the bright 6 doesnt have a warning light for the rear fog......
does anyone know if you have to have a symbol on this light????
