Author: Subject: Horn Label
greggors84
posted on 31/5/06 at 07:36 PM Reply With Quote
Horn Label
Does the horn have to be labelled for SVA?
The reason i ask is the steering wheel i plan to fit after SVA doesnt have a horn button so i was going to wire the horn up to the winscreen washer jets button.
I have to rewire the horn anyway, so if i can wire it up to the washer button it will save me doing it twice. I can cover up the washer jet symbol, either with touch up paint or tape, but not sure how to re label it as the horn if i have to.
Chris
The Magnificent 7!
graememk
posted on 31/5/06 at 07:37 PM Reply With Quote
u dont need a horn for sva
andyharding
You don't need a horn for SVA and it won't be tested so don't worry.
andyharding
posted on 31/5/06 at 07:38 PM Reply With Quote
Damn.
flak monkey
posted on 31/5/06 at 07:42 PM Reply With Quote
Odd isnt it?
There is no SVA requirement for a horn. But its an MOT failure...the system strikes again
Sera
http://www.motosera.com
chockymonster
posted on 31/5/06 at 07:55 PM Reply With Quote
Odd isnt it?
Same as your tyres don't have to be road legal for SVA, as long as they have load markings they are fine
wilkingj
posted on 31/5/06 at 08:19 PM Reply With Quote
I've just got some of those 175 Dba horns.
Now I only need one of those old bus Bell Push Once switches. Cos people will Just push it once!
Best Regards
Geoff
http://www.v8viento.co.uk
graememk
posted on 31/5/06 at 09:14 PM Reply With Quote
where did you get horn that loud ?
Mark Allanson
posted on 31/5/06 at 09:25 PM Reply With Quote
Pardon?
Chippy
posted on 31/5/06 at 10:21 PM Reply With Quote
Another SVA "joke" is that you can turn up with bald tyres, as long as they have the correct speed rating. There is no SVA check on tread. Daft I call it. Cheers Chippy
marshall
posted on 1/6/06 at 05:42 AM Reply With Quote
say you are going to the SVA test and the
tyres are below the legal limit and you get stopped by the police is this ok as you are going to the SVA test ass it is prebooked.....
Marcus
posted on 1/6/06 at 08:11 AM Reply With Quote
No, to drive on the road, you still need road legal tyres. Same for the horn, if you drive it on the road, you need one.
Marcus
Marcus
Because kits are for girls!!
posted on 1/6/06 at 09:15 AM Reply With Quote
My tester checked the horn... nearly deafened him!
(twin air horns)
DJ
posted on 1/6/06 at 11:48 AM Reply With Quote
This is absolutely fine so long as the bald tyres are on your kit car, and the kit car is being towed on a trailer.........
posted on 1/6/06 at 12:32 PM Reply With Quote
But, as had been said before, if you turn up for the SVA with bald tyres, no horn, and whatever else you want to get away with, you can be absolutely sure that the tester will think you're taking the pee and give you no leeway whatsoever during the test - you'll have a fail list as long as your arm!
wilkingj
posted on 1/6/06 at 09:51 PM Reply With Quote
Of T'internet.
Trouble is you need a compressor the size of a bus to drive it. I am now looking for a Rover v8 Air Con compressor with a V belt. That should do it with an air tank.
Best Regards
Geoff
